Question about Kodak EASYSHARE M1063 Digital Camera
I have a kodak easy share MD41. It wont come on
I have a kodak easy share MD41. I am actually on the second one because of the same proble, It wont turn on and refuses to charge. the first one, i had, less than two weeks. this one lasted longer, but the same problem occurs. Is there anything i can do different from your cleaning instructions. Or can anything be done to get a newer or better camera.
  • 85 Answers
That is the most problem of kodak battery once you leave the battery inside of your camer awithout using for a long time. the battery life become less or easily damage.
Posted on Jul 08, 2010
My kodak easyshare MD41 has had charging issues since I bought it.. The USB cable that came with the camera won't fit right into the camera's port. I really had to push to get it in. Well, now it...
You will just need to buy a new cable.
Something like this:
http://www.amazon.com/Kodak-EasyShare-MD41-USB-Cable/dp/B003HMVF70
Hope this helps! Good luck!
Jul 27, 2011 | Kodak EasyShare MD41 Digital Camera
We were filming using the video camera mode on the Kodak EasyShare MD41 and it froze half way through the video when we played it back. Now it has completely frozen and the power button wont work. None of...
Here is an online manual for your camera:
http://support.en.kodak.com/app/answers/detail/a_id/19200/~/kodak-easyshare-md41-digital-camera%E2%A0%E2%80%94%E2%A0extended-user-guide/selected/true
You camera does have a battery and it is possible it simply needs to be recharged.
Jul 26, 2011 | Cameras
Kodak easyshare digital camera MD41, lens extends and closes when start button is pressed with fully charged battery light blinks red and turns off camera
hi open the battary comparment, remove the battery and check to see if there is a small button like thing (looks something like a small horn) there if yes then, press and hold it for roughly 20 secs and release reinsert battery and try powering on this would reset the camera to original factory settings at a hardware level
(i got my other Kodak c340 to work this way)
hope this helps
cheers
May 05, 2011 | Kodak EasyShare MD41 Digital Camera
My kodac easy share c180 wont turn on
This kind of issue might happen. Remove the battery from the came and then press&hold the power button of the camera for 30 seconds.... Put the battery back and then try to turn it back on.......Hope u are sure that the battery has enough charge. If the step does not work try some other alkaline or lithium batteries if possible.
Feb 17, 2011 | Kodak EasyShare C180 Digital Camera
The camera won't turn on, the lens comes out and then back in and the camera turns off. This is a Kodak Easy Share MD41. It's only been used a few times around the home to test it out so it's not been...
The problem is in the systems control board, it is defective or it has detected a problem in the camera. The issue could be the batteries not holding a charge sufficient enough for the camera to run causing it to shutdown. Since the camera has been used so little there must be warranty remaining on the item, it should be returned for quick check where it was bought to get the matter rectified.
Jan 15, 2011 | Kodak EasyShare MD41 Digital Camera
Kodak MD41 camera will turn off immediately after I turn it on. Battery is charged.
go to kodak.com they will assist you in each and every step.......they are awesome try it......
Jul 19, 2010 | Kodak EasyShare MD41 Digital Camera
My Kodak easy share M1063 digital camera wont stay on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak Easy Share V550
mine fell in water and now the lens retracted and won't shut and i have error #45lol
try charging your camera, if it hasn't been broken from the fall, hope it had a soft landing!
Feb 25, 2008 | Kodak EasyShare V550 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
572 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
