Question about Goldstar GW-HD5000 Window Air Conditioner
Smoke or fumes coming from out top
Does this air conditioner take anti-freeze
    President:
  • 2,976 Answers
It's a standard air conditioner. It doesn't need antifreeze.
5000 BTUs is capable of cooling UP TO 150 square feet, with 8 foot high ceilings.
Posted on Jul 08, 2010
  • 6,927 Answers
No,it uses freon.
Anti-freeze leaking from the drivers side
bad hose or freeze plug it could be a lot of things. The coolant runs all through the engine.Maybe water pump gasket.
Jun 06, 2013 | 1996 Jeep Grand Cherokee
My 1997 subaru impreza squeals badly and then engine smokes
Hi this sounds weird does the smoke come out from the front engine covers? the squealing could be the cambelt trying to turn a semi or completly ceased waterpump which would cause the smoke after a while, also without the waterpump working properly the engine will leak water and anti freeze out the overflow and overheat really quickly
Apr 22, 2012 | 1997 Subaru Impreza
Blowing white smoke
white smoke is caused by-- water or anti-freeze entering cylinder . if in radiator or the overflow tank. it will look like a chocolate milk shake. check on oil dipstick for traces of water or anti-freeze. also, a bad head gasket will let water or anti-freeze in combustion area. head gasket symtoms if bad. Symptom #1: Chronic Engine Overheating
Symptom #2: Significant Drop in Coolant Level Symptom #3: Mixing of Coolant and Engine Oil
Symptom #4: White Smoke from Exhaust Pipe
popping of overflow cap Symptom #6: Air Bubbles in Radiator
Symptom #7: Engine Lacks Power GOOD-DAY!
Apr 17, 2012 | Cars & Trucks
Smoke is coming out of below the air filter its connected to the anti-freeze and it over heats?
you have a coolant leak and its burning off the motor (smoke). your overheating because you have a coolant leak. need to pull the air filter box out of the way and find it.
Mar 22, 2010 | 2001 Chevrolet Cavalier
White smoke from tailpipe and low oil pressure
How's the anti-freeze doing? Usually when you see white smoke coming out the tailpipe it's because you are getting anti-freeze in the exhaust somehow. Try to sniff it a little does smell like anti-freeze, or oil? I don't know why the oil pressure would be low unless you are getting anti-freeze in the oil. Does the oil look milky, knda like chocolate milk? The low oil pressure could also be a faulty gauge, you may want to have a mechanic put a mechanical gauge on the car for test purposes.
Feb 03, 2010 | 1995 Mitsubishi Eclipse
2003 cadillac cts v6 3.2 liter. white smoke
u have a leak in the heater core the oily smell and mist is anti freeze sounds like a small leak because usually u would have a wet floor if it was large -two choices check and repair as necessary the core or can use an additive with a stop leak they usually work well on small leaks
Dec 14, 2009 | 2003 Cadillac CTS
Anti freeze smell when car is shut down
do u smell coolant in the car when te doors are closed? if not it is not the heater core, have you had the system pressure tested at a shop? If I had to guess the 2 area's that would cause this are loose radiator hose clamps that just seep, not enough to get to the ground, but enough to smell the coolant, the other a slight leak at the water pump weep hole on the underside of the water pump, this can also be a seep and not reach the ground. Try adding a can of Alumiseal radiator and block sealer, comes in a little aluminum colored tube, about $3 US
Mar 05, 2009 | 2000 Buick LeSabre
Heating & Cooling Logo
67 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
