My model is AEV05KB and recently I see water on the cooling pipes sometimes it drips and sometimes it forms snowlike formations and also if I put the cover on the snow completely coveres the parts inside and when that happens it doesn't really cool the air anymore but it's just like it were on the fan.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 34 Answers
Jkhg
Posted on Jul 08, 2010
    President:
  • 2,976 Answers
It sounds like the unit is too small for the area being cooled. You should figure the square footage of the area and use this th figure what you need.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Using the square footage and the chart below, determine the correct cooling capacity. Cooling capacity is measured in British thermal units (BTUs) per hour.Area To Be Cooled (square feet) Capacity Needed (BTUs per hour)
100 up to 150 5,000
150 up to 250 6,000
250 up to 300 7,000
300 up to 350 8,000
350 up to 400 9,000
400 up to 450 10,000
450 up to 550 12,000
550 up to 700 14,000
700 up to 1,000 18,000
1,000 up to 1,200 21,000
1,200 up to 1,400 23,000
1,400 up to 1,500 24,000
1,500 up to 2,000 30,000
2,000 up to 2,500 34,000
Make any adjustments for the following circumstances:
If the room is heavily shaded, reduce capacity by 10 percent.
If the room is very sunny, increase capacity by 10 percent.
If more than two people regularly occupy the room, add 600 BTUs for each additional person.
If the unit is used in a kitchen, increase capacity by 4,000 BTUs.
Consider where you install the unit. If you are mounting an air conditioner near the corner of a room, look for a unit that can send the airflow in the right direction.
Disconnected condensation drain on hot water heater.
Tankless or hybrid water heater?
Tankless gas must have special fitting between water heater and vent that has a condensate line fitting. Hot toxic vent gasses traveling up vent pipe cause acidic water vapor to form inside vent pipe that drips back down vent and drips onto heat exchanger and other parts eventually burning hole through expensive metal alloy heat exchanger, rendering tankless computer water heater useless after electric circuitry gets wet and shorts out.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#vent
Hybrid or heat pump type computer water heaters must have condensate drain connected to catch pan located just above storage tank and below compressor. Condensation can form on condenser coils and drip into catch pan where there is primary and secondary drain
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#maintenance
Read product manual
Gene
h
Apr 17, 2014 | Water Heaters
I have the LG LP1200DXR and it is leaking near the wheel and i cant figure out why, when we drain it no water comes out what could the problem be?
All air conditioners collect condensate. It has to drain somewhere. Try connecting tubing to the drain hole or port. In order for air conditioners to remove heat from a space, they also remove humidity, which is water vapor in the air. Like placing a cold beverage in a warm room, it will form condensate (water) around it. The water that you were trying to drain out already leaked out. This is a normal thing for condensation to form when cooling. The condensate needs to be emptied regularly or piped with flexible tubing to a window or plumbing.This is the same as water dripping from your car while the A/C is on.
Aug 30, 2013 | LG LP1200DXR Portable Air Conditioner
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
May 26, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
Main water turned off. all fausts opened in house. trying to replace an outside hose pipe. can not stop dripping water to sauter new faust.
Hi. Jam two slices of white bread into the pipe to form a dam to stop the water. Solder the pipe. Then turn the water back on to clear the bread from the pipe.
Aug 14, 2011 | Plumbing
After my air conditioning has been on for about 30 mins it sometimes drips liquid on my feet - what is causing this?
The air conditioning coil that cools the car should be in a tray that collects the condensate and drains under the car or perhaps down through the engine compartment. After running the air if you pull into your driveway and stop you should see water dripping. If the drain gets plugged it will overflow the drain pan and drip in the car. This may be what is happening. Look around near the firewall for the drain pipe/hose. Be careful if the engine has just been run.
May 25, 2010 | 1994 Ford Escort
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
Water coming from indoor unit
The problem is caused by fine particulants such as dust, pet dander, etc. which mix with the collected condinsation water and forms a grey gel eventually clogging up the drainage pipe. The solution is to attach a wet vaccuum hose to the discharge end of the drainage pipe and vaccuum out the gel. It is advisable to flush the system by adding water to the a/c's drain pan while the vaccuum is still running.
Oct 07, 2009 | Mitsubishi Heating & Cooling
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Odor
Sorry I don't know this model, so I can only give generic advice on this one.
Most fridges have the cooling plate at the back. Try to keep food away from it, otherwise ice will form on it.
At the bottom of this area there will be a gully and drain hole through to the back. Any drips that form at the back, will drip into this gully, go through the hole, down a pipe and onto an evaperator tray sitting on top of the compressor.
What usually happens is that dust or labels get stuck to the cooling plate at the back, which drips down, blocking the pipe, which then stagnates into a grey stinky soup.....Lovely!
What you need to do is defrost the fridge, spray clean the inside with a multi-surface cleaner, and flush this tube with the cleaner water. A turkey baster syringe may be the easiest way to do this. As the evaperator tray only holds about 1/2 a cupful - don't overdo it.
While you are there, clean the door seals.& dry the interior.
This should cure the problem.
Thank you for using Fixya!
Jun 14, 2008 | Whirlpool GD2SHGX Refrigerator
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
