Question about Ruud UBHC Air Conditioner
Air Conditioner not working
I was weed eating yesterday and I got tangled in what looked to be the wires that go to the thermostat, well needless to say my AC shut down and once I hooked the wires that I cut back up still a no go, I checked under the house and followed the wires all the up and to the thermostat and it is fine, there are actually spots where it is zip tied off to prevent to much tension, there is what looks to be a momentary test button on the side of the AC under the electrical panel and when I press it the fan kicks on, but like I said it is momentary. I also took apart my thermostat to see if anything was fried and it looked OK too. I deal with car electronics all day (i know not completely the same but) I know what a bad electrical board looks like. Either way, all the breakers are good and are not popped so I don't know where else to look.
  • 456 Answers
Check on the board and see if the 3amp fuse is blown,if you do not have
a fuse in this board, then check for 24volts between R and C, if you do
not have voltage there your transformer is blown, it will also have a bad
burnt smell if it happened
Posted on Jul 17, 2010
3 amp fuse blows when ac is switched on. Heater works fine.
There is a short in the low voltage wires somewhere for sure. The most common place is the low voltage on the outside unit, sometimes animals chew through them or they get cut with a weed eater. Just my experience. You basically have to trace it back all the way to the thermostat and heater. The only other thing is the contactor
Jun 30, 2012 | Carrier 38CKC060 Air Conditioner
Dometic rooftop a/c compressor will not shut off. The only way to stop the compressor is to shut it off at the breaker. The fan and all other funtions operate properly from the thermostat. I tried...
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Oct 03, 2011 | Dometic 57915531 Air Conditioner
Son weed eating and hit wire outside now have no eletric to thermostate and wont come on wire is not broke into
The transformer may be shot. Place the fan switch on the thermostat from auto to run. The indoor fan should come on. If it doesn't then the transformer is probably bad. You can check for power on the transformer primary and then the secondary. If you have power on the primary and not on the secondary then it is no good either.
Sep 12, 2010 | Heating & Cooling
Rheem outside a/c fan won't turn off
I would probably start at the thermostat and see if 24 volts is continued to be applied to the yellow wire which calls for unit activity even though you have called this off. Shorting the cool (yellow) wire to the return (red) wire will cause the HVAC system to begin cooling and the fan will be turned on automatically.
Aug 23, 2009 | Ruud UAMB042 Air Conditioner
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
My air conditioner will only turn on for a moment then shuts off
it sounds like you have a thermostat problem you can either take the thermostat of the wall and check the wires to see if they are all connected, or you can replace you t-stat. you also could have a bad contactor. without having technical knowledge it will be hard to fix, your best bet is to call an A/c shop and have a tech look at it.. it shouldn't be too pricey. 60 for the tech to diagnose it and if its the contactor it shouldnt be much over 100 dollars.
Jun 05, 2009 | Intertherm P3RA-048K Air Conditioner
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
look on indoor unit to see what they used if only ac unit then only 2 wires needed common usually blue or black and yellow if heat pump then orange for rev valve o term on stat r red y yellow then white or brown for call for elect heat in defrost and blue or black for common also take some 3/8 clear tube to incase the stat wire and zip tie it to top of line set to help stop this
May 07, 2009 | Intertherm P3RA-030K Air Conditioner
My airconditioner for the house is not working we change the electronic thermostat an still not working we replaced the fuses an its not improving would it be because of my dogs eating the wire's that are...
there could be a short in the wire. meaning that its not getting the proper voltage. do you have any other symptoms? make sure that the breaker is not tripped, and if it is, it very well could be from the dogs eating at the wires. that could also kill your dogs if they get hit with that voltage coming from the wries.
Apr 22, 2009 | Goodman CKL24AR24 Air Conditioner
Condensing unit
Probably one of the wires going to the control board or contactor has been pulled off when this happened. If you feel comfortable trying to reconnect these comment me back and I will try to walk you through it. PLEASE REMEMBER THAT THE CONDENSER HAS HIGH VOLTAGE INSIDE OF IT.
Jun 27, 2008 | Goodman CLQ36AR49 Air Conditioner
Intertherm gas furnace model number m6bb070abfc01
Check for a open limit switch caused by a dirty filter or poor air flow
Dec 24, 2007 | Intertherm P3RA-048K Air Conditioner
Ruud UBHC Air Conditioner Logo
42 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
