When set for cooling, generating only hot ait. Connections seem to be per the manual. Could it need freon recharge?
SOURCE: Soleus MA-9000AH blows hot air
Sounds like the compressor is not running. This model had lots of problems with over heating. It also will never really blow more than a moderate cooling through it. Since you have cleaned all the filters and is still 100 deg, I believe the failure will be the compressor itself or the capacitor.
If you find an oily residue in the drain or on the pipes, it may have simply leaked the refrigerant out. Good Luck!
SOURCE: The Plug on my Soleus
This mean the compressor is drawing too much amps, caused by the back cois are clogging up and not getting rid of enough heat.Hope you clean it soon before it ruin the compressor. Thank-you-very-much!
SOURCE: soleus mac 12-k air conditioner runs for 45
first of all an amp reading needs to be taken to see how many amps the AC is drawing. It may be too much for the breaker. Also see what else may be wired in on the same circuit, there may be additional load on the breaker. If all amp readings are below the rating for the breaker then you may have a faulty breaker, but that's pretty unlikely. The most probable cause is you are overloading the circuit.
SOURCE: How to keep the fan speed on low at all times on
dear sir
i think your air conditioner,s micro controller system is not working well, that why this problem is coming .please contact to your product dealer for replace it .
hope answer the question
thank you
please vote!
