Question about Dometic 57915531 Air Conditioner
The LED lights on our Dometic Duo therm receiver don't work and thus the remote comfort control won;t work all breakers and fuses have been checked
    President:
  • 1,561 Answers
Since the breakers and the fuses as been check and they are not defective, the problem is most likely from the control board in the furnace that is causing the problem, do you have the reset instruction for the remote? you will have to take the intake cover off the A/C to get to get off the box, while you have the cover off, check the wires that connect to the the circuit board to see if any is damaged because this could be damage that is why the led light is not coming on.
Take care.
Posted on Jul 08, 2010
  • lwollen Jul 08, 2010
    Here is what we did- Plugged the RV directly into a outlet (no extension cord) then when that didn't work we unplugged fron AC and totally disconnected the batteries left it 20 minutes hooked everything back up and everything worked. I guess its resetting everything like when your computer gets bogged down, I do the same So Thanks anyhow
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
No power in contol unit
dc check fuses a.c check breakers.
Jun 07, 2014 | Dometic 3312024.023 Duo Therm Comfort...
Blank screen no numbers
se if you have 12 volts dc available might be a fuse.
Feb 06, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
No display
takes 12 volts d.c to work.
Jun 16, 2013 | Dometic 3109228.001 Duo Therm Comfort...
No 12 volt power to duo therm comfort control box
check if you have 240V and then 12V to the secondary of the transformer if none then its your transformer that is faulty
Aug 02, 2009 | Dometic Rooftop RV Air Conditioner
Dometic control comfort control will not turn heat on or off
I had the same problem. I fixed it by turning off the battery switch to disconnect the battery from the power panel. I then had to turn off the main 110 breakers to shut down the converter. Once all the power was turned off the LED light went off. When I turned the power back on the remote was working fine. Hope this works for you.
Jan 09, 2009 | Dometic Rooftop RV Air Conditioner
Dometic 57915531 Air Conditioner Logo
65 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
