Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a Whirlpool Cabrio Top Load Washer and it has started flashing af code and stops the whole washing process. I found online where it says af is airflow prob. What is that and how do I fix it? I've only had this machine for a year and a half.
    Champion:
  • 274 Answers
The water pump has air so try this ajusting drain lines or see if theres blockage in drain line try running with out load.
Posted on Jul 08, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
    F1 (F60-68)
    Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
    See Accessing & Removing the Electronic Assemblies.
    F1 flashing on the display indicates a primary control failure.
    "F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
    The link below lists Cabrio failre codes.
    http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
    Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washer stops and F 51 flashs
    Hello, It is a rotor position sensor code. The control is no longer receiving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor.
    Thanks
    Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Error f1 flashes after just a few seconds of turning on the wash cycle. if i turn off power and try to start again it will somtimes start if not i turn off and try again sometimes it takes 3 or 4 times to...
    The Whirlpool Cabrio and Kenmore Oasis (same machine) are infamous for this problem. Depending on the serial number you may be entitled to a new control board installed for free under a recall program. Call Whirlpool for eligibility. I had just had mine replaced last week for free and it runs fine now.
    Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
    Press STOP/CANCEL to clear the display and completely cancel the cycle
    flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
    Press START to continue the cycle from the moment that power was lost
    Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 code whirlpool
    whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Machine started filling with water - then stopped and flashed F
    I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
    Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washer is showing a code f1
    press PAUSE/CANCEL once to clear code. press start.if code reappears call for service
    Mar 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio code F50
    I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
    Nov 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    155 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
