Question about Ovens
Am looking for a Brisbane supplier for a Campini TY95 thermostat
Cannot locate a supplier
    President:
  • 1,891 Answers
Don't know where you are ? but you can order on the web from www.apdepot.com. @ sears parts.com. and many others . that may be in your area . try google. for appliance parts.. mm
Posted on Jul 16, 2010
I need a thermostat for bosch oven serie Nr HEK66X83EH/01. FD8708
Fixya does not sell replacement thermostats. Check with a local appliance parts supplier.
Jul 20, 2016 | Bosch Ovens
Where can I buy a replacement thermostat for a diplomat mt60 oven. Model number apl5520/21
An appliance parts supplier might have one or can order one.
Jul 01, 2016 | Ovens
ECS 130 SCH
Check your phone directory to locate an appliance parts supplier.
Sep 03, 2014 | Ovens
CAMPINI Ty60
It is a thermal limiter. Same happened to me with kenwood . Am in the process of sourcing repacement. Can only find on the overpriced sites at mo eg partsmaster
Apr 11, 2012 | Baumatic B205SS Stainless Steel Electric...
Fan oven not getting warm
It is normally the element that has gone, located behind the fan. A long shot could be the thermostat. Have a look at the thermostat sensor. It will be located in the oven at the back somewhere. It should be clean and bright and not covered in dirt or grease etc. If it needs a clean, use a spray cleaner and do not treat it to harshly. The thin wire leading from it is quite fragile! However, if you decide to replace the heating element, I would suggest that you replace the thermostat as well because quite often the element blowing damages the thermostat, which could lead it to fail, it it hasn't already done so, at a later date.
Oct 31, 2011 | Stoves 720EF Electric Double Oven
Frigidaire oven is slow to heat then exceeds set temp set
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Oct 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
Need actual part
possibly you are looiking for the thermostat
May 18, 2007 | Whirlpool RBD306PD Electric Double Oven
Ovens Logo
189 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
