Question about Dometic RM2193 Compact Refrigerator With Ice Box
No cooling on gas, works great on elect.
Have Dometic RM2193 frig in 1996 camper, and it works great on 12 and 120 volt power,but doesn't cool at all on gas. I have a good steady blue flame and a clean flue tube and burner and don't know where to go now. Any ideas? (product #9211310-06) ........Thanks Ron
rshi5@yahoo.com
  • 3 Answers
I had a similar problem. The flue would get hot and the cooling tubes would get "warm". The refrig would get a LITTLE cool but nothing to be of any help.
I solved it though...it turns out there is a "flue baffle" (twisty little metal thing) that is supposed to hang in the inside of the baffle. It hangs from a screw found on top of the baffle and it is supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a coat hanger, then rehanging it using a new screw. That solved my problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding it. Item B is the screw that was corroded on mine, and ended up dropping the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
Posted on Jul 28, 2010
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
I use a Dometic RM2193 in my pop-up camper. Can anyone tell me what temperature differential I should be able to acheive on 120VAC, propane and 12VDC? On 120VAC I was getting about a 40 degree fairenheit...
Usually from the Bottom of the refrigerator you should have minimum of 43f or colder than ambient. Should work very close to same on both gas and 110, on Dc it may not cool as good. From your description you may have an issue with ventilation. Cold air needs to flow in through the lower vent and out through the upper, if it cant, cooling efficiency is lost. Adding a fan kit can help on hot days. On gas you may have particles that fell down in the burner. Just take the cover off, take the burner screw out and blow down into burner to clean out. compressor or canned air works fine. If cleaning the burner doesn't improve it enough on gas to match electric you have to make sure your regulator on your rv has enough pressure... the fridges require 11 inches of water column.
May 03, 2017 | Dometic RM2193 Compact Refrigerator With...
Dometic rm2193 will only cool to 50 Electric and gas is ok
Do you mean it runs OK on gas ?
If so you probably need an element.
If not , you need a new sealed system
Aug 17, 2009 | Dometic RM2193 Compact Refrigerator With...
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM2193 Works on 120V, but not on gaz. I succeded in cleaning the burner jet and I get a flame. It ligth well now but the flame very small. The frig doesn't cool. Help ?
These fridges require that the control switches be in the correct position for the power source you want to use. If you try to operate the fridge on gas and have the electric 120V-AC switch on, all you'll get is the gas pilot light to stay lit. Also, when running on gas, the electric has to be off.
Here's a link to the manual for your unit. Print a copy and save an electronic one for future use, in case you lose your printout.
Hope having the manual helps you to get the fridge working on all the power sources you need! Best regards!
Jul 03, 2009 | Dometic RM2193 Compact Refrigerator With...
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM2193 Compact Refrigerator With Ice Box Logo
289 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
