Question about Kenmore Freezers
I keep my freezer in my garage, and It is warm out there, but I've noticed that the sides of my freezer is very warm to touch,on sides is this natural. it has been a very good freezer, and is almost 20 yrs old.
    Novelist:
  • 101 Answers
Most units now use condenser coils hidden inside the walls of the unit verses exposed in the back. If your unit does not have exposed coils or a forced air cooled condenser then they are most likely in the walls which would make what you are describing completely normal. Just make sure you allow 3 to 4 inches of room around them to let the system cool itself.
Posted on Jul 08, 2010
Upright Freezer won't Cool
Hi - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Oct 14, 2012 | Frigidaire GLFH17F8HB Upright Freezers
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Aug 22, 2017 | Kenmore 14.8 cu. ft. / 419 liter Chest...
To whom it may concern: My mother owns a freezer manufactured by Kelvinator (Masterpiece, Model No. CA08MT) that she purchased approximately twenty-five years ago. Yesterday, I noticed that the front and...
Good day,
If the freezer is performing properly then in warm weather this is entirely normal. That is the condenser tubing and as it gets warmer, the inside gets cooler.
Jul 21, 2010 | Freezers
Gibson Upright Freezer
Is it a self defrosting? Or not? And how did you defrost it?If you scraped and chipped the ice away, you may have poked a hole in the evaporator and the refrigerant (freon) leaked out.
Jan 03, 2010 | Frigidaire Freezers
Refrigerator/freezer in garage doesn't keep food frozen in winter
Yes there is a solution. You need to install a garage Thermostat Heater. This will trick the thermostat into thinking it is in a warm environment. This article will tell you why this is happening and the solution as I described. Sorry but for some reason I cannot post this as a link. Copy & Paste into your browser. http://applianceparts.wordpress.com/2009/01/12/why-won’t-the-freezer-in-my-garage-refrigerator-freeze/
Dec 07, 2009 | Kenmore Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Broke down after 3 years!! Any ideas on what wrong and how to fix it?
Hi Bill,
You will not like this repair at all. It is cheap and easy but usually really gross. So hold your nose and read on.
This time of year we have little visitors in our garages that like to find a warm place to cuddle up. They will crawl into the back of your freezer and find your warm compressor and start looking for places to build a house. While walking around they will eventually walk directly into the condensor fan and and usually they will not die, they will just be stuck in the fan blades. The heat that begins to build up will slowly cook the little critter and you will get a foul smell for a couple of days. Then you will notice the freezer has stopped cooling well. To repair simply remove the rat from the condensor fan and you got it fixed. In some cases the fan can burn out from the jam so you may need to replace it. I always hate to do this job, it is easy but who likes to handle a cooked rat??? Grossss.. Please dont forget to rate me and try to have a nice day.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Exterior side walls VERY hot
Hi wjjlaw,
ngafm at your service,
Is the hot side th open side or against the wall or cabinet side?
Have you touched this side before in he two years you have this appliance? Or is it that you just noticed it?
And if you can keep your hand on that spot for a long time it is not so hot only warm? If it is not burning your had it is probably just the characteristic of that fridge!
Check if the freezer part is full to the top and packed full.
Freezers can not be so full that you cover the cold air vents usually found in th rear of the freezer.
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
Please give me a good rating before you sign off.
Thank you.
Sep 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Aug 19, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Freezer making noise & left side of the freezer (on outside is very warm to touch)
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Nov 02, 2007 | Freezers
Freezers Logo
87 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
