Question about Canon Office Equipment & Supplies
Re: Canon PIXMA MX347, I tried copying through the ADF but the printer con't ''scan from ADF''. What is wrong?
old marine
  • 2005 Answers
SOURCE: having problem copying from ADF
On this model, the Intensity needs to be set to 'Manual' to make copies from the ADF.
1. Press the 'Settings' button repeatedly until 'Intensity' is displayed
2. Press the left or right arrow until 'Manual Adjust' is displayed, then press the 'OK' button
3. Press the left button to decrease the intensity, or the right button to increase the intensity, then press the 'OK' button
4. Press the 'Back' button repeatedly to return to the Copy standby mode
To return to 'Auto Adjust', follow the above instructions selecting 'Auto Adjust' at step 2, and skipping step 3
Posted on Aug 28, 2009
greg_margo
  • 1959 Answers
SOURCE: Canon pixma MP600, error code 5010, what does it mean
There are a few things you can try:
  1. Power reset; press and hold the Power button until it the machine starts a diagnostic mode; if this doesn't turn on the machine, unplug it for 10 minutes and upon plugging it back in, see if the error reset itself
  2. Unplug all USB devices (including the printer) and reboot the computer. Once the computer has rebooted, plug in the printer, allow it to install (it should install automatically) and see if the error is corrected. Sometimes there can be a temporary conflict and the only way to solve it is to remove all other USB devices (this can work for external hard drives too).
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Posted on Nov 09, 2009
Testimonial: "Thenk you very much for your assistance, I will try your solutions. regds Robert"
  • 3 Answers
SOURCE: On my Canon Pixma MP780 a vertical line appears on copies made using ADF
I tried the other solutions listed here - and no luck. After cleaning the inside of the ADF, like the manual suggested - no change. How are you supposed to do that anyway? Deep cleaning the inside of the machine also has nothing to do with it.
I finally figured out why things that I copied with the ADF had lines/marks on them, but those placed directly on the platen (big glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Posted on Dec 03, 2008
SOURCE: Canon PIXMA mp240 All-in-one InkJet Printer. Error code: 2,140,2
I had exactly the same problem (error Code:2,140,2) in Canon PIXMA MP250, and it was solved when I replaced both ink cartridges which were almost empty (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Posted on Jul 27, 2010
SOURCE: Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Posted on Apr 15, 2011
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
Error message with canon mx410 "cannot scan from adf"
I fixed this by changing the Copy Intensity from Auto to Manual
I had the same paper jam (caused by pressing Stop during a page going into the ADF), but I had pressed OK as instructed and the page was auto fed back out again. Then I couldnt copy from ADF after that.
I tried everything, and then started to retrace my steps of all the things I might have tinkered with to try and get the copying working in the first place, before the paper jam.
Then I remembered I had set the Copy Intensity from Manual to Auto (thinking Auto is always best). With hindsight, it now makes sense for it to be manual with the ADF as otherwise how would it load a page, use it to set auto density, and then reload it again for the actual copy to occur. This happens okay on the flatbed scanner as it can scan a little, work out the settings, and then scan for real.
Copy Intensity is reached on my Canon MX from the Menu button at the bottom left of the front panel. - Then press the right arrow twice to get to Color Intensity. - Hit OK. - Then right arrow from "Auto" to "Manual Adjust"- Then pick a setting or leave it as half-way between light and dark- Press OK
Now every time my ADF copying works a treat. Thats what I get for tinkering in things I didn't need to change in the first place. I was just trying to get a quick copy going from ADF to paper without saving a file up on the computer and then printing.
Aug 09, 2012 | Canon Pixma MX410 All-In-One Printer
Canon MX410 won't scan from the adf
Thank you, old marine! That fixed my problem!
Feb 12, 2012 | Canon Pixma MX410 All-In-One Printer
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Need driver for canon pixma mx347
You can download your Canon Pixma Inkjet Printer from here http://downloadnew.biz/drivers/printer/canon-pixma-mx347-mx340-mp-driver-517631.html Hope this helps.
Please rate if this solution was helpful,thanks!
Jul 14, 2011 | Canon PIXMA MX340 Wireless Office...
Does canon pixma mx 310 work faxing page up or page down?
When using the ADF load the document with the side you want to copy, fax or scan facing UP in the ADF.
When using the platen glass load the document with the side to be copied, faxed or scanned facing DOWN on the platen glass.
Trust this helpful.
Please vote.
Dec 15, 2010 | Canon PIXMA MX310 All-In-One Printer
In copy or scan mode, the page is almost all solid black
The scan assembly has gone out. Parts are not available except the entire scan assembly, I can get you a part number and price if you like.
Jun 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scanning using Printer control
Did you install the full printer driver package?
The printer has to start the appropriate scanning SW on your PC.
Aug 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
385 people viewed this question
old marine
old marine
