Question about LG DLE5977 Stainless Steel Electric Dryer
Does not dry clothes, keeps turning off prior to
Does not dry clothes, keeps turning off prior to complete drying. takes multiple drying cycles to dry clothes completely. I have cleaned the lint vent and the vent out the back.
    Champion:
  • 274 Answers
Then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Posted on Jul 08, 2010
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
Fridgidaire Dryer not drying completely
Good Morning David, thank you for allowing me to assist you!
I understand your dryer is experiencing lack of heat. There are several factors that could cause this; some of which you can check prior to scheduling a professional.
Have you checked your lint filter recently? I ask because if a lint filter is full of lint it will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder area after each and every use. Check the lint filter for any buildup of fabric softener that will also restrict airflow and wash with soapy water to clean. If the filter is damaged then it will need to be replaced.
Additionally to checking the lint trap area, please investigate the ventilation (duct work) system connecting to your dryer. Often we forget to clean this duct work therefore over time debris can restrict air flow. Check the air flow by disconnecting the accordion-like duct work from the dryer appliance. Run a drying cycle, with clothes inside the unit, but keeping the duct work disconnected. If you notice any improvement, then the ventilation duct work (often going through your floor or side wall) will need to be thoroughly cleaned. Also make sure you do not have multiple turns or kinks in the duct work. The more curves or turns this duct system has to take to exit the air outside, the more restricted it can get. The more restriction you experience the more time it will take the unit to dry.
Do you notice any unusual rumbling or rubbing noise when in use? This could indicate a faulty blower wheel. A blower wheel that is not firmly attached to the motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat (a fuse like component) may trip and turn off the heat circuit. A loose blower wheel will usually make a rumbling noise that is easily noticed. Inspecting the blower wheel is usually a task for a professional considering you must take apart most of your appliance to make sure it is tight to the motor shaft.
If you have a gas dryer, gas valves could also cause you an issue. Defective gas valves can create a symptom of taking too long to dry if they are intermittent and require professional attention. A professional is needed to check for proper flame ignition for a complete drying cycle to determine if this may be your point of concern.
On many dryers you will find "drum seals" in between the unit's drum and the front door. The drum seals are used to prevent excess air from entering the dryer drum and act as a cushion between the drum and the front and rear access. The drum seals are made up of a felt like material. If the seal is torn, or is worn, then clothing can become stuck in the gap when the drum is turning. This can produce a scraping or thumping noise and the clothes can also be ripped and/or have black marks on them. This will also affect your drying time tremendously.
While you are checking the drum seals please check the door of your dryer as well. When the door is closed in gas and electric dryers the door seal helps to keep cooler air from entering the drum. Keeping the correct temperature at all times inside the dryer ensures that the clothes will dry efficiently. If clothes are not drying then inspect the door seal for signs that it may be worn or damaged.
If none of the above solutions prove to be successful, it would be advisable to contact an experiencing repair tech to assist further.
Best of luck!
Nov 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
Takes multiple cycles to dry normal load of clothes
Have the vent system from the back of the dryer to the outside of the house cleaned. If the dryer can't push air out, it can't bring air in, and the clothes won't dry. Another condition you might be seeing is moist lint developing around the gasket on the inside of the door. That's a sure sign the airstream is restricted somewhere.
Apr 25, 2009 | Dryers
Takes multiple cycles to dry one load
Clean the dryer vent all the way to the termination site and then clean inside the vent in the dryer. Make sure it is clean of lent. The blower assymebly can also become clogged as well but try the vent hose first. If it is completely clean and it's still haveing trouble, it could be the thermostat on the unit and it is not allowing the dryer to cycle properly.
Apr 10, 2009 | Dryers
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
LG DLE5977 Stainless Steel Electric Dryer Logo
285 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
