Question about Maytag Ovens
I was in contact with technician , gave him my credit card info. but was cut off.needto continue with questions and answers.....
  • johnnymae1 Jul 08, 2010
    nOT MUCH--nOW I CAN'T GET THE BROILER TO LIGHT. NEEDED TO COMMUNICATE MORE ON THE PROBLEM BUT COULDN'T ET AN ANSWER----I DO NOT WANT THE MONTHLY SEFRVICE. SO IF I HAVE SIGNED UP FOR IT--CANCEL
    IF THERE IS A SOLUTION FOR MY OVEN AND MY BROYLER--OTHER THAN REPLACING THE IGNITER--PLEASE E-MAIL ME...jOHN
  • 2,272 Answers
Explain your problem here.So it can be helped.Mention your problem in proper detail. Keep updated.Thanks.
Posted on Jul 08, 2010
  • raj somaiya
    raj somaiya Jul 08, 2010
    Replacing the igniter is necessary because igniter is the part which lets the oven to glow to get the burner lit.
    but in some cases removing then cleaning the igniter as well as its connections makes the burner lit.Also try cleaning the holes of the burner if they are blocked.Then check but if still the same problem then its the faulty igniter which has to be replaced.
    For getting required parts you can get it from the on-line site like www.repairclinic.com
    Thanks for the appreciation and mentioning your query and keeping updated.
Oven will no light
Re POST make, model #, and complete question so we can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 27, 2016 | Ovens
My baking Element has continuity, but will not heat
Re POST , make, model #, and complete question so we can answer your question effectively.
Feb 26, 2016 | Ovens
Will aluminum foil protect credit cards
No! They make special cases for protecting them from radio wave theft devices.
Oct 06, 2015 | Ovens
When you open the oven door it will fall all the way open.
Carrie,
You probably have broken door springs. If you put in the make and model of your stove, it did not come through with your question. With that info, we could answer your question with more accuracy.
May 29, 2015 | Ovens
Does this need to be hard wired on installation?
Your failure to provide fixya experts with the needed info,i,e,;make,model,year,exactly what the nature of the problem is,can get you all kinds of answers,we deal with 1,000's of questions without the needed info on a daily basis,if you expect a good reply then give the needed info!!!
Apr 29, 2015 | Ovens
Frigidaire freestanding gas oven pilot light is out
Hello - Hi - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Oct 20, 2012 | Frigidaire Ovens
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
WHAT IS THE SIZE OF THE CUT OUT HOLE
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
Jan 09, 2012 | Thermador Ovens
After self cleaning oven no longer heats up
Sometimes the only way to solve this problem is to contact me or another Whirlpool Technician. Reason being Whirlpool has taken a very strict course of action when people post Whirlpool manuals here or the public on-line. I also have 5 days a week that I can contact Whirlpool if the question is a hard to solve answer. This is rare. The problem you are having is related to possibly your door lock or thermal fuse and once self cleaning begins you are having a fault that turns the power off and can only be resolved by doing a series of diagnostics. Click here and this page will explain=> RBS275PD Electric Single Oven fault Resolution.jpg I will be happy to assist you (should it come to that) and others here at Fixya. Click=> Here and fill out the capsha. after I saw your post I pulled the service manual to see if there by chance was a one answer solution and it appears that you will need to follow the instructions if you request I will send. We all love those easy answers and this will be much easier one on one, Thank You and thanks for choosing Fixya, Sea Breeze
It could also be simple as a defective=> 9759243 Thermal Fuse
Parts Manual=> RBS275PD Owners Manual=> RBS275PD
Please rate this solution, Thanks, Sea Breeze
Mar 27, 2011 | Whirlpool RBS275PD Electric Single Oven
Open Questions:
Ovens Logo
16 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
