Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
My hot rod deluxe has internal distortion problems.
My hot rod has distortion problems. When the distortion is off, the yellow distortion light shows up (intermittently) and the sound is not right (neither clean nor distortion) When I turn the distortion on, it switches back off (light turns yellow) when I play any amount of sound at all through it. When the clean channel is on, and the yellow distortion light does not turn on, sometimes the red distortion light comes on, but very faintly and intermittently. But when this happens, the sound does not change other than buzzing or loose connection sound. This is not a connection problem with the pedal or cord (i.e. outside of the amp), as it does this when the pedal is not plugged in too.I don't see any obvious signs of burnt capacitors or loose connections on the circuit board. Help!
  • Fender Master
  • 5,603 Answers
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Posted on Jul 08, 2010
Testimonial: "I haven't fixed the problem yet, there is more to it now that I have pinpointed the general problem, but he was right on the mark."
  • 1 more comment
  • jooooooey Aug 22, 2010
    Thank you very much, that helps. I looked closer at the circuit board, and it appears to be burn out around the /- volt power source. So I think that you were right.
    The source of the problem seems to be the two 470w 5w resistors where the power sources come in. But when I check them with the multimeter, one of them reads about 480 and the other reads about 490. I would have expected them to be less resistance, or no signal, if anything. The problem is not my multimeter. Other than the circuit board, there the resistors don't appear to be damaged.
    Now, one of the circuits on the actual circuit board may have been burnt out (i am not getting a signal through it). I can repair that, and that may be what is causing the amp to cut out. But then, what is causing the resistors to heat up so much in the first place?
    I had the same problem probably 5 or 6 years ago, and I took it in to be repaired. The repairman replaced my tubes and did some work on the circuit board. For all I know, the burnt out spot on the board could be from that first time, at least some of it.
    Should I replace the tubes? Do they wear out that fast? I have read that bad tubes will cause those 16v resistors to get hot.
    Is there supposed to be that much variance in the 470 ohms 5w resistors, or are they damaged?
    Now there are 2 zener diodes in the circuit which are right next to those 2 resistors which also appear to be burnt at least on the board. I have not checked those yet.
    Should I replace the zeners, the resistors, the tubes, AND the broken circuit on the board, or is that more than is needed?
    Any advice or help would be appreciated. Thank you very much.
  • Fred Yearian Aug 22, 2010
    Resistors have a tolerance and readings of 480 or 490 is acceptable limits
    Where board is burned, look for bad soldering. The 470 ohm screen resistors will run hot and may discolor the circuit board.
    For the intermittent distortion light I suspect the switch that is a part of the footswitch jack may have poor intermitent contacts.
    Plug a low resistance device (like a speaker) or 1/4 inch rod into the footswitch jack to make a firm contact and see if distortion light still changes intermittenly...
    Capacitors C49 and C50 are also suspect. Both ar 22mfd/25v electrolytic capacitors.
  • jooooooooey Oct 18, 2010
    The 480 resistors commonly get hot and burn the board on the fender hot rods. What can solve that problem (of the board getting burnt) is to raise the 480 resistors off the board by using resistors that have longer wires coming out of the sides..
    The problem on my amp was not the power source however, but in the foot switch circuit. It was not the pedal. There was a loose connection on the LED light which tells if the distortion is on (red), light distortion (yellow), or clean (no light). I resoldered the connection and it fixed it.
    Thanks for the help all the same.
My hot rod deluxe switch channel from clean to distorted for him self without me touching anything?
I have worked on a number of these amps and found the most common cause of intermittent channel switching is dry joints on the foot switch jack or the contacts becoming contaminated. In either case you will require a tech to look at your problem as the main board will require being lifted out of the metal chassis for inspection. Because of the ribbon type cables between main board and the board that supports all the valves I recommend professional help . Not a DIY job
Apr 24, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Crate three button foot swich how do you connect it to the amp
The Fender Hot Rod Deluxe shows a 2-button footswitch as standard but I'm confused. This link shows it as connected to the amp via a mono cable ... FENDER Hot Rod Deluxe DeVille Footswitch which is impossible using two switches. Normally it's a stereo (tip, ring, sleeve) with tip to sleeve being one connection, and ring to sleeve the other. Good luck with this one.
Apr 22, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Hot rod deluxe squeals terribly with either overdrive box or distortion box. seem fine with tremolo or chorus box.
I have had this problem at least two times and the fault was a bad hi voltage filter capacitor. With the back of the amplifier removed, it's the grey cap near the top right side. Warning: very dangerous voltage there!!
Jul 20, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I have distortion on my clean channel I have changed the speaker but still same problem
Look at your indicator LED... is it off for the clean? Does it show yellow for drive and red for more?
Depending on if this LED is showing these correctely tells me where to look for problem. If the LED shows these correctely, then problem is with the relays that do the switching or a few transistors that change the gains for the drive and more functions.
May 04, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Hotrod amp is distorting on the clean channel once it goes past 3,is it a speaker problem or is it tubes?
to rule out the speaker, you could try one of 2 things.
1. remove the speaker from the cabinent and gently push the diaphram in 1/2 an inch to 3/4 an inch, as far as it will gently go- BE GENTLE. the speaker should recess and return to normal position smoothly, without any scratching or rubbing, or internal resistance., the only resistance should be from the paper cone itself, not internal to the speaker. if there is any rubbing or scratching from the inside (inside the area surrounded by the magnet), or any changes in resistance (not smoothly moving) as the speaker goes in or out, then the voice coil is damaged.
2. find another speaker of suitable wattage and ohmage, and disconnect the hot rod's internal speaker, and hook the replacement speaker up in the internal speakers place. a speaker of 50-100 watts should be suitable, and it will probably need to be 8 ohms- a standard bookshelf speaker may be suitable if it is a suitable wattage and ohmage rating (stamped on the back of the hot rod's speaker magnet and/or on the back of the external speaker/cabinent as "8ω",) do not, and again, do not, under any circumstance disconnect or connect a speaker while the amp is on, or even plugged in. touching the positive and negative speaker leads together, even briefly, while the amp is powered will fry the amplifier circuit, and you will smell it!!!
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
On low volume using the clean channel the sound is great but as soon as you get to about three or more the sound gets a bit distorted,the amp is the fender hot rod deluxe, ithort i may had blown the...
try a differrent speaker of suitable wattage and ohmage (displayed with a number next to a ? symbol on the back of the speaker),
or
remove the original amp speaker and gently push in and out on it, checking for uneven resistance or scratching. the speaker should retract and return smoothly, without any scratchiness or uneven resistance from within, and if there is any of this scratchiness or uneven resistance from within, the speaker is likely damaged from too much wattage or distortion.
Switches between clean and distortion channels while playing
The circuitry for the channel switching is rather messy; Here is schematic:
http://elektrotanya.com/fender_hot-rod-deluxe_sch.pdf/download.html
I would first suspect the foot switch jack assuming you are not using the footswitch. There are many components but switch contacts, especially on the jack are very suspect.
It will take a little patience to find the problem... vibration can rattle the contacts or any loose soldering.
Feb 06, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe Volume Fluctuations. My amp (fender hot rod deluxe) will occasionally have volume fluctuations when I'm playing. The changes usually occur when I've moved my setup from one place...
First thing would be try another guitar with the amp. This will eliminate if it's a problem with the guitar or the amp itself. If the guitar is working properly then check all the tubes to be sure they are all seated into there slots completely. Depending on how much use they have been played it may be a good suggestion to then replace your tube's. Occationally the tubes will start loosing power, making sound fluctuate up and down or distortion sounding static in background noise. You will notice a big difference with newer tube. But remember the bias must be set correctly to match the new tubes so they won't over heat. You can check out youtube for setting the bias. Anyway this is my suggestion and I wish you good luck.
Jan 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
634 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
