Question about Keurig Elite B40 Coffee Maker
Sounds as if water is coming through, but no water drips through
I have descaled it with vinegar, even though the descaling light was not on
  • Keurig Master
  • 1,711 Answers
This normal not a problem at all you should do that if you hard water.
Posted on Aug 10, 2010
Wont take water from reservoir
You have to descale it, even though the light probably never came on (it never comes on for me). It happens to mine and I refuse to replace it until the descale doesn't work anymore. You need a large bottle of white vinegar. After you have that the first thing I would do is remove all the water, that includes whatever is inside of your machine. Unplug it and tip it over the sink to get the water out. Plug it in again, fill the reservoir with white vinegar. Turn the unit on and cycle it (like you are making coffee) over and over until the light comes on to add water. I would use ALL the vinegar in the bottle. After you run out of vinegar, file the reservoir with water and cycle the machine. Continue to do this until you have filled the reservoir 4 times. It's a little boring, but it should fix the issue.
Jan 23, 2014 | Keurig Elite B40 Coffee Maker
Descaling instructions bosh filtrino fast cup
It took me ages to get his to work - seems that on the THD2023GB (Black) Filtrino, you push and hold the temp. set button for 10 seconds to get he descale programme running.
Sep 30, 2012 | Bosch Thd2021gb Filtrino Fast Cup Hot...
Can't drip even after descaling
If you just used the liquid commercial type descaling solution, Unplug it and look underneath the arm where the hot water comes out onto the coffee grounds. Take a toothpick or even a pin and make sure all those teeny holes are not plugged up with hard water and other debris. If this doesn't work, maybe the pump is bad?
Jun 21, 2012 | Coffee Makers & Espresso Machines
The message "descale" is on and even though we
the best and cheapest descaler is vinegar. Let it sit in the machine for a couple of hours and then run it through a few times. Works wonderfully!
May 02, 2011 | Keurig Platinum B70 Coffee Maker
Heavy scale buildup runs out of steam normal descaler doesnt seem to make much of a difference. would some vinegar help
HI
Descaler is 100% acid and straight vinegar is 5% and descaler has no taste. Vinegar is not recommended by any manufacturer. If scale has built up that heavy, you had your water hardness set to low which most everyone does. I have mine set on 4 even though I use good water. There is a product call Durgol that is a liquid, where you could run a heavier solution to try to remove the scale. Yours is a 208v machine, so you want to make sure that you use the descale mode in the menu or you could cause your boilers to leak. I have some if you need one.
Feb 10, 2011 | Saeco Royal Cappuccino Espresso Machine
Not enough water making it from holding tank to dispensing cup
your machine is "Short Cupping"
It needs to be descaled. Even though the descale light might not be on yet, the descale light only comes on when it is in SERIOUS need of a descaling. You should descale once every 3 months.
Fill reservoir with distilled white vinegar and leave the machine on for 4 hours (make sure to turn off the auto off option).
after 4 hours, run the vinegar through the machine until the reservoir is empty. Refill with water and repeat twice. you will notice a difference right when you start running vinegar through.
Apr 04, 2010 | Keurig Elite B40 Coffee Maker
Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Aug 01, 2009 | Keurig B50 Coffee Maker
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
How do you descale the keurig B40
use descaling product not vinegar ,vinegar remove calcium in little piece descaler melt calcium 1 part descaler 1 part water fill water container start machine for a few second turn off let it seat for 15 minute repeat untill empty to reset the lightnormally its maneer of pressing the on button
i get back to you on that one pierre
Feb 24, 2008 | Keurig Elite B40 Coffee Maker
Cleaning light came on and lost manuel on how to clean it
1 part descaler 1 part water put that in our water container stsrt it up rince very good especialy if you use descaler . descaler is better than vinegar descaler melts the calcium vinegar remove calcium in little piece thanks for using fixya pierre
Feb 13, 2008 | West Bend 56860 10-Cup Coffee Maker
Keurig Elite B40 Coffee Maker Logo
343 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
