Question about Pioneer DEH-P7700MP CD Player
Auxiliary too quiet when using my iPod!
The volume coming from my speakers is fine when listening to a CD or the am/fm tuner, but when i plug in my iPod i can barely hear anything with both iPod and head unit volume cranked, and all loudness settings on high. The auxiliary cord is plugged in snugly as well, please help
  • brentreimer Jul 08, 2010
    wiped off both ends of the aux cable and doesnt seem to be any shorts of any kind in the back, any other ideas?
I have done some reverse engineering on the
DEH P7700MP I don't have a way to draw a picture but I solved the Ipod audio problem.
The Jack on the back is totally useless.Low or little audio. I used a 2 or three foot stereo audio wire, stripped and tinned red white and ground. There is a blue multi pin jack where I would suppose the Sat Radio plugged in. I took a micro screwdriver while stereo was in AUX mode and carefully touched each pin until I heard a Hum from right and then left speaker. There were actually 4 pins I found but worked best with only 2 right and left. Power down radio Solder red to one pin and white to the other. Ground the ground wire that was braided to the screw on the radio case near the plug. Re power the unit by pushing the volume and reset the aux feature. Worked pretty good for me and not bad volume. Be careful never solder a live radio you will smoke it for sure..possibly have someone that solders well do it for you. Kinda tricky.. Good Luck!
Posted on Dec 22, 2010
  • 24 Answers
Clean all conects with acohol and cheak for shorts
Posted on Jul 08, 2010
    also i have tried plugging in my blackberry and my older ipod nano, same results so there isnt anything wrong with the ipod
Sound is really quiet with inputs
Hello. Please be sure that you are plugging your iPod into the tape in, or play, and not into the record out, or record. If you have these reversed, you will greatly lower the signal level going to the amplifier.
Dave
Oct 08, 2012 | Harmon Kardon HK AVR20II
Tip
How do I use my iPod adapter in the SX4 Crossover
<p>The SX4 is a small car produced and designed by Japanese automaker Suzuki. There is a vehicle that comes with the option of an iPod sound, but there are numerous adapters that can be purchased and installed for this purpose. <br /> <p><br /> <p>1. Buy a cassette adapter and the SX4 has a cassette player. Place the tape in the stereo. Connect the other end of the adapter into the iPod headphone port. Press "Play" on the deck. The adapter will play on the iPod as if it were output through a stereo cassette on the SX4. <br /> <p><br /> <p>2. Purchase a wireless FM transmitter. Connect the transmitter to the iPod. Tune in the FM radio station without a SX4 to use. Tune the transmitter on the same drive, and press "Play" on the iPod. <br /> <p><br /> <p>3. Buy an auxiliary input, and installed by a professional if you do not have extensive knowledge of the years SX4 radio. Many retailers will provide free installation with purchase. The cable is connected to the auxiliary input on the stereo, and into the cockpit of the SX4. You can connect the headphones to your iPod while you listen through the speakers is the SX4. The sound is almost perfect. <br />
on Aug 09, 2011 | Apple iPod touch
I have an old Harmon Kardon amplifer (15 years old). When I connect my ipod to it via an ipod to hi-fi cable jack plug to 2x phono cable, I lose volume in one speaker. When I move the volume control knob I...
what your having is a power feedback,, Ipods are very low wattage,, the receiver however is much higher. the same thing happens when you hook an Ipod to a car with amps attached.
May 04, 2011 | Audio Players & Recorders
Is it possible to listen to an ipod threw old stereo speakers?
If it has an auxiliary jack or if you have an FM transmitter, yes.
Oct 02, 2009 | Apple iPod nano
Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
Connection compatibility
Connect the supplied short RCA "Y" adapter cable to the mini jack of the transmitter base unit. Connect the "Y" adapter plugs to the TAPE 2 "REC" L and R jacks. These jacks will supply "line out" levels of any source selected at the Kenwood to the EWOS1 internal amplifier. The line out levels are "fixed" so changing the volume levels of the Kenwood will NOT change the volume out of the EWOS1 speakers. The EWOS1 volume will be controlled by the volume up / down buttons on the front of each speaker, or by the incuded remote when directed at the speaker(s).
The signals from the TAPE 2 jacks are ALWAYS on regardless of the source selected, so the Kenwood volume can be turned to minium and still provide an unchanged sound level from the EWOS1 speakers. Likewise, if listening to FM, Phono, CD, etc. in the room that the Kenwood's speakers are located, the OWS1 speakers will by playing the same FM, Phono, CD, etc program - unless they have been powered off. The point is, that unlike having to choose FM, CD, etc to listen to those soreces, you should never select TAPE 2 as a source. If TAPE 2 is selected, the KENWOOD would attempt to amplify TAPE 2's "PLAY" jacks, which I assume are not being used.
Mar 20, 2009 | Audio Players & Recorders
Alpine ida-x001 volume is low even if stereo is turned all the way up only when ipod is plugged in on ipod setting.Radio (AM/FM) is normal volume (louder)..How can I fix this?
Most newer car receivers have a feature named something like "level balancing" in which you can adjust the relative loudness of each input (Tuner, CD, AUX, IPOD). Check you owner's manual for a similar function.
Also, are you or can you turn the level of the ipod itself up a bit?
Mar 07, 2009 | Alpine iDA-X001 CD Player
I need to add and auxillary input to my 2003 chevrolet silverardo bose radio. how can i wire one in?
THE GM12-AUXV2 by P.I.E. will work for you.
It plugs into the factory radio changer port.
With this device installed, you will have created an auxiliary audio input to your factory radio, which will allow you to plug in any external audio source, like a portable MP3 player, satellite tuner, DVD player, or iPod, and play the audio from that external audio device directly through your factory radio. This is a direct connect device and NOT an FM Modulator. An FM modulator requires you to tune to an FM radio station in order to listen to the audio from the external audio device. While this is a direct connect interface, it is only an audio connection and does not allow you to control the external audio device that is connected to it.
Jan 19, 2009 | Car Audio & Video
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
Pioneer DEH-P7700MP CD Player Logo
583 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
