Question about One For All URC4220 Remote Control
I need codes on all for one universal remote for tv zenith
Sparky-UK
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
SOURCE: Zenith ZN110 Univesal Daewoo tv Code
a gpx dvd player
Posted on Apr 28, 2008
IrishDruid
  • 2712 Answers
SOURCE: remote codes
Zenith codes: 0017, 0016, 0092
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 17, 2008
aprmaejun
  • 97 Answers
SOURCE: philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
Posted on Jun 21, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
Phillips universal code for zenith tv
Try these codes. 0738,0826,0284,0888,0000. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
Universal Remote Controll Codes for a Zenith TV
These are the codes for Zenith TV: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Aug 04, 2012 | Big Button TV Universal Remote
We need a Universal Remote Control Code for a Zenith TV
Four digit universal remote codes for Zenith TV are:
Jun 27, 2012 | Zenith ZN620 Remote Control
My universal remote needs a code to be programed to my tv. my tv brand is zenith
There are many codes for Zenith TV's. First, try this website:
http://www.jascoproducts.com/support/universal-remote-codes.asp
Note if your remote uses 3-digit codes or 4-digit codes, and choose the appropriate code list.
May 02, 2010 | Universal Remote Control GE174Universal...
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
Need one for all code for zenith tv
what is the code for all for one remote to zenith tv
Nov 07, 2009 | Televison & Video
Need universal code for philips sru3004 universal remote
here are some sites with your code.
www.remote-codes.com
www.tvcodes.com
www.universal-remote.net/philipsmagnavox.html
Apr 15, 2009 | Zenith TVBR1342 13 in. Combo
Need code for ge jasrm24912 universal remote control zenith tv
I have a brand D tv and i am trying to get a code to program the remote control GE JASR24912 3- Device to my tv .
Jan 16, 2009 | GE RM24912 Universal Remote Control
One For All URC4220 Remote Control Logo
87 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
