Question about Honeywell CT3600 7 Day Electronic Programmable Thermostat Heater
Honeywell st6100 7day timer for Central heating.NO POWER
The ST6100 has power on the display,But No power (from st6100) is going to Thermostat unit via a cable in another room.
I think its the Relay in the ST6100, but not sure.Please Help!
Buffalo12980
  • 625 Answers
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Posted on Dec 07, 2007
SOURCE: changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Posted on Feb 16, 2008
SOURCE: central heating timer
Does it have batteries?
Posted on Apr 05, 2008
SOURCE: HONEYWELL CM921 ROOM THERMOSTAT
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
Posted on Oct 27, 2008
  • 6 Answers
SOURCE: Honeywell thermostat won't regulate temp properly
Is there a setting on your thermostat that makes the unit stay on for 10, 15, 20, 25 minutes after you reach set temp. You can change this setting by looking at your manual for the thermostat. Not sure if there is one for this thermostat but mine has one. Mine was running 15 min after set temp and making it cool down 2 degrees lower than set temp. Hope this helps.
Posted on Jun 25, 2009
Cannot set timer on central heating/water system.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jul 27, 2010 | Honeywell Heating & Cooling
Programmable Thermostat Heater: no power to honeywell central heating control...
Multiple possibilities:
Damage to cable (doing any DIY?)
Failure of thermo
Board gone in heat unit
Possibly simple as loose or disengaged connection, check at thermo & heat unit, if nothing obvious, call serviceperson.
May 18, 2010 | Honeywell Programmable Thermostat Heater
My honeywell timer for the back boiler heating is blank
need to contact the people who worked on it yesterday to come back and look at it again because it sounds like you have no power to now.
Jan 29, 2010 | Honeywell CT3600 7 Day Electronic...
CT3600 display went out. Replaced all 3
My honeywell CT3600 thermostat went blank.
Replaced batteries - no change ?
Dec 25, 2009 | Honeywell CT3600 7 Day Electronic...
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Central heating programmer
is the buttons still working, eg, boost, on/off etc? or is the heating not working?
If so the LCD/Control panel may have lost power, this usually a switch/or fuse that may have been accidently powered of or blown
Feb 20, 2008 | Honeywell Electronic Programmable...
Installing a honeywell CM900 wireless programmable thermostat
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
251 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
