Question about Kenmore 99123 Electric Kitchen Range
I have kenmore electric stove. the two large element dosen't work
I have kenmore electric range stove. the two large burner not working. I have cheked the element it is good. some body please help ?
    Champion:
  • 274 Answers
Try the controlls or switching the elements with the other buners.
Posted on Jul 08, 2010
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Dual burner wont work on a maytag jeco52oa4db13
I tried to find your specific range by Google search, but the only reference to the "jeco----------" is on this forum, so I couldn't determine whether this stove is a gas or electric model.
IFyou are talking about an electric stove burner, then either one of the elements is malfunctioning or broken, or the contacts are dirty or otherwise not making good connection to the stove's burner receptacle. The way to check this is to remove the burner element and swap the similar element into its place to see if it works properly. Assuming the receptacle is not dirty or contaminated with debris, the burner should work normally. If it doesn't (but DID work in the receptacle you pulled it from) then either the receptacle itself is dirty/corroded/contaminated, or the control switch is bad.
Nov 22, 2013 | Maytag Kitchen Ranges
Frigidaire stove front large/small burner combination. Large burner works but the small burner in the centre of the large burner does not come on at all with any heat. ??
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Oct 23, 2013 | Frigidaire Gallery GLEFM397DS Electric...
I have a kenmore 953 freestanding stove, my wife was making pizza and the oven made a strange sound, the display is no longer working, the oven stopped heating, and she attempted to turn on the burners,...
If you will type "SearsPartsDirect" into your search engine, you can then enter your model number and you will see all the parts of your stove.
What should have happened was, either an element failed, or the element wire connection inside the wall of the oven failed, or a wire has "toasted" in the electric box inside the back of the stove.
You will need to take the oven out (away from it wall, perhaps) & give it a good inspection with an electric meter to find out where the problem lies.
God bless your efforts.
Oct 02, 2017 | Kenmore 9535 Electric Range
Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Large Heating Element no longer heats
Is it the eye itself or the receptacle? solution: yank out the questionable eye and put another from the stove in that one. swap em around and determine if the eye is bad or the receptacle. The receptacle are around 10 bucks.
9f0ea2e.jpgpart number 330031
Mar 02, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Whirlpool R365 Large Burners won't work
The problem could likely be in the sockets that the elements plug in to. Over time, they lose tension and deteriorate. The replacement sockets are relatively cheap and easy to replace. If the connection ends of the elements are still in good shape, there is really no reason to replace the element.
Oct 19, 2008 | Whirlpool RF365 Electric Kitchen Range
Kenmore 99123 Electric Kitchen Range Logo
657 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
