Question about GE 25GT240 25" TV
No power just went out..... - GE 25GT240 25" TV
    President:
  • 1,099 Answers
  • A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.Note that it *may be* useful to replace a fuse the *first* time it blows (though it would be better to do some basic checks for shorted components first as there is a small chance that having a fuse blow the second time could result in additional damage which would further complicate the troubleshooting process). However, if the new one blows, there is a real problem and the only use in feeding the TV fuses will be to keep the fuse manufacturer in business!
    Sometimes, a fuse will just die of old age or be zapped by a power surge that caused no damage to the rest of the TV. However, it must be an EXACT replacement (including slo-blow if that is what was there originally). Else, there could be safety issues (e.g., fire hazard or equipment damage from too large a current rating) or you could be chasing a non-existent problem (e.g., if the new fuse is not slo-blow and is blown by the degauss circuit inrush current but nothing is actually wrong).
    If the fuse really blows absolutely instantly with no indication that the circuits are functioning (no high pitched horizontal deflection whine (if your dog hides under the couch whenever the TV is turned on, deflection is probably working).) then this points to a short somewhere quite near the AC power input. The most common places would be:
    • Degauss Posistor - very likely.
    • Horizontal output transistor.
    • Power supply regulator if there is one.
    • Power supply chopper (switchmode) transistor if there is one.
    • Diode(s) in main bridge
    • Main filter capacitor(s).
    You should be able to eliminate these one by one.
    Unplug the degauss coil as this will show up as a low resistance.
    First, measure across the input to the main power rectifiers - it should not be that low. A reading of only a few ohms may mean a shorted rectifier or two or a shorted Posistor.
  • Test the rectifiers individually or remove and retest the resistance.
  • Some sets use a Posistor for degauss control. This is a little cubical (about 1/2" x 3/4" x 1") component with 3 legs. It includes a line operated heater disk (which often shorts out) and a PTC thermister to control current to the degauss coil. Remove the posistor and try power. If the monitor now works, obtain a replacement but in the meantime you just won't have the automatic degauss.If these test good, use an ohmmeter with the set unplugged to measure the horizontal output transistor. Even better to remove it and measure it.
    • C-E should be high in at least one direction.
    • B-E may be high or around 50 ohms but should not be near 0.
    If any readings are under 5 ohms, the transistor is bad. The parts sources listed at the end of this document will have suitable replacements.
    If the HOT tests bad, try powering the set first with your light bulb and if it just flashes once when the capacitor is charging, then put a fuse in and try it. The fuse should not blow with the transistor removed.
    Of course, not much else will work either.
    If it tests good, power the set without the transistor and see what happens. If the fuse does not blow, then with the good transistor (assuming it is not failing under load), it would mean that there is some problem with the driving circuits possibly or with the feedback from the voltages derived from the horizontal not regulating properly.
    Look inside the TV and see if you can locate any other large power transistors in metal (TO3) cans or plastic (TOP3) cases. There may be a separate transistor that does the low voltage regulation or a separate regulator IC. Some TVs have a switchmode power supply that runs off a different transistor than the HOT. There is a chance that one of these may be bad. If it is a simple transistor, the same ohmmeter check should be performed.
    If none of this proves fruitful, it may be time to try to locate a schematic.
  • hope this helpout.....
    Posted on Jul 08, 2010
    The display screen for my DGX 500 is blinking on and off and is unresponsive.
    Do you mean,"The HOUSE power went out" or, "The keyboard power went out"?
    Mar 20, 2012 | Yamaha Music
    Power went out. Is there a way to reset it?
    If all the power went out in your whole house, then you need to flip the main breaker switch off then back on again. This should restore power.
    If only frig went out, then which secondary breaker switch is "triggered" and flip off then back on.
    Dec 31, 2011 | Refrigerators
    Went to use microwave and it just went dead. Household power is fine and breakers are good. Replaced main fuse behind switch panel and got power back for clock etc.. When I went to run it again, it went...
    short circuit in high tension power supply
    DUE TO THE VERY HIGH AND DANGEROUS VOLTAGE 4000( V) IT IS NOT WISE TO FIX IT YOUR SELF UNLESS YOU KNOW WHAT YOU ARE DOING
    Apr 26, 2010 | Maytag MMV5100A Microwave Oven
    32"stoped working went black
    you need to replace the power source. You can get one from Power-On.com for about $64.00 including shipping and handling. I had the same problem and this solution solved the problem.
    Dec 29, 2009 | Protron PLTV-32 Television
    Vizio plasma. screen went black, and the power light went out.
    Sounds like the power suply went. I don't know that model off the top of my head, but you might find a replacement here http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=EU&Category_Code=PLA
    -=/ Daft Tech /=-
    Oct 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
    I have viewsonic 1703wb monitor. Often Monitor power went off
    Check the power cable. If it uses a power brick style assembly (like a laptop) it may need to be replaced. Some power bricks can break a wire at the base of the brick just enough that it causes a short in the system and shuts down the power flow.
    Mar 19, 2009 | ViewSonic VA1703wb Monitor
    Screen went black; power cord is working but won't power computer
    the power plug on the laptop may be loose or broken
    Mar 03, 2009 | Acer Aspire 3680 Laptop
    GE 25GT240 25" TV Logo
    149 people viewed this question
    Top GE Televison & Video Experts
    Computer Repairing
    Computer Repairing
    matt martin
    matt martin
    Are you a GE Televison and Video Expert? Answer questions, earn points and help others
