Question about Dryers
Dryer goes on then turns off before times up wont turn back on
    Champion:
  • 274 Answers
Well it dry clothes ,it may be getting to hot,see if lint trp is plogged up,
Posted on Jul 08, 2010
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Circut breaker turned off then turned on dryer wont turn back on (kenmore serial #86982800)
i ve seen this in the field alot of times make sure you actually are getting full 220 to unit.. sometimes these dang breakers look like they are on but they fail to send full power back to unit... it is even happened to me in the field i go to turn power off to a customers unit and when i am ready to turn back on the breaker wont fully reset... check it out if it was working prior to the bresker turned off and you didn't operate on the dryer disconnecting or replacing anything this is your problem...
Jan 02, 2011 | Kenmore Dryers
Replaced Kenmore dryer heating element. Element worked initial after being installed one time. Turned dryer off and moved dryer back. Turned the dryer on a second time and it now wont work. Drum will turn...
I would pull dryer and re-investigate the element to make sure no connection came off and to verify the coil did not burn in half. Hope this helps Tim
Aug 29, 2010 | Kenmore Dryers
The dryer is not heating. The Heating element turns on and some times the flame comes off the then shuts. Most of the time the flame won't turn on
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Kenmore 24032\24036 Top Load Washer
The dryer will not heat. The glow plug glows but the gas does not turn on all of the time, I got it to turn on one time when on the permapress setting.
heatman101
Aug 19, 2010 | Maytag MLG15PD Gas Commercial Dryer
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 | Dryers
Replace dryer belt
take off back of dryer....belt goes around tub and a pully on the motor....its fairly easy...when you get on there youll see...just make sure the tub is alligned correctly when you get it back together...turn the tub manually a cfew times before turning on and unplug before repairing......thanks and have a great day
Nov 08, 2009 | Amana NDE2330AY Electric Dryer
Wont turn.
the belt goes on over the drum and around the pulley under the drum you either have to take the top of the dryer off or the back panel to get at it
Sep 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My gas dryer turns o but wont heat up
Hi, thanks for the inquiry.
It's most likely a thermal fuse. Basically, the voltage has to go through the fuse
Before it goes to the ignitor.
If it's an electric, it's either the heating element or the thermal cut-off, most of the time.
Either way, it should only cost you about $90 to repair.
Best of luck :)
Aug 30, 2009 | Dryers
Whirlpool duet dryer gew9250plo dryer will not turn on
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram heaver red wire for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
Top Dryers Experts
