Question about Lexmark X5470 All-In-One InkJet Printer
Well I put a total of 256 and gives me a message of you need to upgrade to 512 ok I think I" am going to push this great computer on the floor real hard and see if it bounce. help!!! thank you
    Genius:
  • 3,587 Answers
Hmmm..well..512 will definitely make it work faster
Posted on Apr 19, 2008
I have a Packard Bell desk top PC In 2006 I Installed windows vista I noticed I needed a 512 ram as I had 256.I bought a 512 ram I knew were to install It ,I took the 256 ram out and carefully put In...
You put in the wrong type of memory. Put the old 256 back in the computer should power on with no beep code(or all good beep). If this is correct make sure to obtain the same type of memory as the 256. Also both slots must have the same RAM. You cannot have a 128 with a 512. They should both be either 128 or 512.
If you are using Vista you should have a minimum of 1g RAM.
Jun 08, 2011 | Computers & Internet
I have A30 8199 with initial 2 ram card of 256 for total of 512 meg. I purchased 2 new cards of 512 each for total or 1Gig. I am on Win XP home and have all updates to XP with Bios of 5/10/05. When I...
Looking over at crucial.com it says that your A30 can use PC2700 and PC3200 DDR. Maybe go other there and see if your new ram matches what they sell. I know it's not much but maybe a start.
Apr 26, 2011 | Lenovo IBM ThinkCentre A30 8199 (8199XX2)...
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
I have a Easy Note M5 280DW and would like to know if I can upgrade the RAM?
Standard Memory 256 (256MB x1 Removable) Maximum Memory 1 GB The standard memory of your system is 256 Mbytes and the maximum memory it supports is 1 Gbytes.
So you can either upgrade the RAM by adding 1 stick of 256 Mbytes (for a total of 512 MB) or buy two sticks of 512 Mbytes each (for a total and maximum memory of 1 Gbytes).
You are looking for PC2700 DDR Memory.
In any case, check the memory you have installed.
You can download a free utility like CPUZ that will give your information about your system, including the number of memory slots available and used and the memory (amount and type) installed: http://www.cpuid.com/download/cpuz/cpuz_152_setup.exe
Aug 03, 2009 | Packard Bell Computers & Internet
Upgrade memory for Compaq Presario R3000 PC Notebook
What OS are you running? 768 should be enough to run XP and keep you from getting that error message. On laptops their are normally just 2 slots for ram, so you would need to replace the 256 with the 512, which would bring you up to a gig of ram. Do you know if your computer has any spyware/adware on it? Sometimes malware can take up all your memory and generate just such an error. Do you know how many processes are running when you first login? Thank you.
Apr 10, 2009 | Compaq Presario R3000 Notebook
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Maximum Ram upgrade?
this is the link
http://www.memorystock.com/memory/ToshibaSatellite2400103.html
In this link u have following details
1)Maximum capacity RAM Information Available
2)Toshiba Laptop Memory Installation Video
3)Laptop Memory SODIMM Installation Guide
If you r Satisfied with information provided from my side please give me good ratings thanks
If u require more information search in google
Aug 09, 2008 | Toshiba Satellite 2400-S251 Notebook
Purchased more memory from 256 to 512 the tech that installed the memory installed the 512mb DDR 2100 and left one of the 128 chips installed to give a total of 640mb ram receive error message "out...
Run Registry Editor (Regedt32.exe).
2. From the HKEY_LOCAL_MACHINE subtree, go to the following key: \System\CurrentControlSet\Control\Session Manager\SubSystems
3. Select the Windows value.
4. From the Edit menu, choose String.
5. Increase the SharedSection parameter.
For Windows NT:
SharedSection specifies the system and desktop heaps using the following format:
SharedSection=xxxx,yyyy
Add ",256" or ",512" after the yyyy number.
For Windows 2000, Windows XP, and Windows Server 2003:
SharedSection uses the following format to specify the system and desktop heaps:
SharedSection=xxxx,yyyy,zzz
Increase the zzz number to "256" or "512."
Best Of Luck!!
Jul 21, 2008 | Gateway Computers & Internet
Not loading all-one-cd
ahhh...well...you only have 128 meg of memory? That will mean that most applications will be really slow...time to come up to speed, methinks.
Apr 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
