Question about Amcor AF 12000E Portable Air Conditioner
I have a AF12000E air conditioner 2 years old. I
I have an Amcor AF12000E air conditioner 2 years old. I set it up and turned it on today and the compressor light stayed on 5 minutes and is now out. Does this mean the compressor is not working? I set the temp for 79degrees and it reads 83, so further cooling needs to take place.
  • 3,083 Answers
I would think the unit might just need recharging, since the compressor shouldn't go bad this soon. There's also the possibility that the thermostat is bad. The unit needs to be checked out.
Posted on Jul 08, 2010
  • share_al Jul 08, 2010
    I bought the unit at Home Hardware in Vernon. Where do I take it to have it checked out? Will it be under warranty? Thank you. Sharell
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
AMCOR 24,000 BTU split system. Worked fine two years, then today it had no power. Checked circuit breaker, it had popped. Reset CB and went to inside unit - would not turn on or off with remote or hard...
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Aug 09, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Lost user manuel
Bob, you can obtain a copy of the manual for free by following the link below:
http://www.retrevo.com/support/Amcor-PLM14000E-Air-Conditioners-manual/id/12860bh732/t/2/
You may have to create an account to get the manual - but there is no fee associated with doing so.
I hope this helps!
Jun 18, 2010 | Amcor PLM-14000E Portable Air Conditioner
Fan works, cooling doesn't
check your condensor for dirt and any resets
Apr 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
Amcor AF 12000E Portable Air Conditioner Logo
141 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
