Question about Logitech Z-2300 Computer Speakers
No sound I just recently moved, when I plugged my speakers in for the first time after the move, I have power, but no sound whatsoever. What's the problem?
I just had the same problem.
Take a look at the gold connectors where the remote cable attaches to the subwoofer; they bend easily when moving the speakers.
If one of them in bent, use a screwdriver to fix it. That should do it.
Posted on May 17, 2008
  • 25 Answers
Be sure they are plugged into the right jack on back of sound card. Also, plug speakers into a second different PC with good working sound. This will verify that the spaekers are still ok. If speakers are ok, then check in control panel under Sounds, see if a sound cscheme is selected. If No Scheme selected, select one, then respond NO if prompted to keep scheme.
Posted on Apr 30, 2008
Everything is plugged in turned on but no sound. I recently moved my computer system to a new location and have not been able to get the speakers to work help
I assume this is a powered unit, so first off make sure the power cord is plugged into the wall and the speakers. then make sure you are plugged into the correct jack on the PC. It is usually green in color. Finally, make sure the volume on both the speakers and the PC are turned up. Report back wit hresults.
Jul 01, 2011 | Harman Kardon Audio Players & Recorders
I have a Toshiba 50HX70... I fixed the convergence issue around 6 months ago. Now the sound does not work... I turn it all the way up and you barely hear anything... I did move it recently, did I know...
Best best would be to try the following:
Start with taking the back cover off of the tv.
1) Verify if you can hear any sound whatsoever out of the speakers. If so, that would indicate that the speakers are still connected to the circuit board. If not, then trace the wires from the speakers to where they plug on to the board.
2) if you hear sound (hiss) in the speakers, but not the audio signal from your program you are watching, then look to ensure all connecters are fully seated around the RCA jacks in the back.
If those two do no produce results, then could be a solder joint on the board finally failed after moving the tv, or the amplifier for the speakers has failed. If you hear sound though as in step 1 above, i would doubt it is the amplifier IC.
Feb 20, 2011 | Toshiba 50HX70 50" Rear Projection...
I can't heard no music why?
Several possibilities come to mind: speakers have failed (self-powered speakers have bad power brick, cable damaged, etc), speakers plugged into the wrong port (audio in instead of audio out), audio card or driver has failed.
If you recently had to restore your OS (or do a roll-back to a "known" good configuration), check your audio device (make and model) and make sure you have the latest driver installed. (Look at the website for your computer if it is a prebuilt system or look up your motherboard if it is an on-board audio device.) The device manager might have a yellow exclamation mark on the audio device if this is the issue (access from the Windows Control Panel)
Check for bad speakers by trying another set of speakers or plugging them into another computer. (Swap cables if that is possible.)
I hope this helps.
Apr 23, 2010 | Dell Inspiron 530 Desktop Computer
I recently moved and after i plugged up my pc the speakers dont work. they dont even turn on. any ideas?
If you have external speakers with no power, I would first ask if you plugged in the speakers power supply cord? That would seem to be the main problem....No power to the speakers.
If this is not the problem, let me know and we will look into this further.
Brian
Apr 12, 2010 | Dell Dimension 3100 PC Desktop
I have acompaq presario 6000 but when I moved and plugged my speakers bak in al I get is static. I cannot get any sound. I plugged the speakers into another computer and they work just fine so the speakers...
Make sure you are plugged into the small green 3.5mm jack. if there is no sound whatsoever, then it is a failed amplifier. if there is staticky sound then you likely have a failed 3.5mm jack. Try plugging the speakers into a headphone port (if available) or disable to on-board sound device, puchase an add-in 3d soundcard and circumvent the issue.
Oct 01, 2009 | Compaq Computers & Internet
Sound problems
your speaker connections are plugged in incorrectly or the speakers are not plugged in and powered on.
check the back of the computer where your speakers are plugged in and make sure you speakers are plugged into the right colors
May 31, 2009 | Computers & Internet
No sound from my BA745 speakers
Make sure you have the right speaker wire (green plug to green socket)
You should have three wires going into the right speaker, the left speaker, sub woofer, and the power wire...and one wire coming out as mentioned above.
double click on the speaker (lower right corner of the monitor) and make sure the volume levels are normal. And too check the volume level on the right hand speaker.
hope this does it for you,
PLease leave rating...thank you
May 14, 2009 | Boston Acoustics BA745 Computer Speakers
My computer speakers just went silent in the middle of a song
Do the speakers have power? Check the fuse.
Where are you plugging your headphones?
Where are the speakers connected? Is it the same jack as the headphones?
Have you tried plugging the speakers into the headphone jack vs the soundcard?
Mar 13, 2009 | Harman Kardon HK695 Computer Speakers
Only getting half the volume
The first things I would check would be the volume control within your operating system. If I assume you have Windows XP, you would go to Start-->All Program-->Accessories-->Entertainment and click "Volume Control". Make sure all of the sliders are at least 1/2 way up. You might also want to check to make sure the cable from the speakers to the computer is plugged into the proper jack (usually the green one), as sometimes computers have jacks for rear speakers, which might make them sound quieter.
Mar 04, 2008 | Logitech Z-2300 Computer Speakers
Logitech Z-2300 Computer Speakers Logo
79 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
