Question about Dell Inspiron 6400 Notebook
My DELL Inspiron 6400 cannot connect to my DSL Internet, what should I install to make my Dell Internet connection Work... Further the Memory Card Reader also does not work, what else is missing?
  • Brad Brown Jul 08, 2010
    What happens when you try to connect?
    Please list the errors.
    What is the version of windows that you are using?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
You wrote:
"My DELL Inspiron 6400 cannot connect to my DSL Internet, what should I install to make my Dell Internet connection Work... Further the Memory Card Reader also does not work, what else is missing?"
YOu can try system restore, think of the possible time where your computer was working properly without hussel then that will be your restoration point, or better try to back up your files and do tjhe factory image . Since this is a DELL computer pressing CTRL+F11 will do the factory default setting of your system that is why it's highly recomended to back-up files first before doing this.
Posted on Jul 08, 2010
Does DELL Inspiron 6400 has a inbuilt microphone? If it does how to make it work?
I am sorry to say but, the 6400/E1505 does not have an internal mic. You need External. Sorry. Specs only show a MIC connection. I/O Ports IEEE 1394 4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors Flash Memory Slot - Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, xD CD type I/II, & IBM Microdrive through ExpressCard adapter Video: 15-pin monitor connector S-Video: 7-pin mini-DIN connector Audio jacks: Stereo headphones/speakers mini-connector (same as line-out), microphone mini-connector
Dec 09, 2010 | Dell Inspiron 6400 Notebook
My laptop is del inspiron 6400,i have installed a new os ,windows xp. i have downloaded drivers but i have a problem in installing network drivers . iam given the information of uncompatability of hardware...
Connect your laptop to the internet using Wifi (obviously network connection not available due to your problem) and update the drivers for the network adaptor. Can you use a free Wifi point somewhere to connect via Wifi to help with the driver issue?
There will be a yellow exclamation mark next the network adaptor problem in the WINXP System Properties. To get here right click on My Computer, then select Properties, then Hardware, then Device Manager. Find the offending network card problem, double click the device, Select Driver, then Update Driver. Let WINXP find the driver from the internet.
Alternatively, check the driver you downloaded from the Dell support webpage. Are you sure it was the correct driver for WINXP for the same model of network card fitted to your Dell 6400? A message about incompatible hardware means you are trying to use drivers on hardware which is not compatible with that driver. That is a good sign that you dont have the right drivers.
Go to Dell here: http://support.dell.com/support/ and select Drivers and Downloads.
Try this link here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=DRVR&formatid=-1&servicetag=&SystemID=INSPIRONI6400%2FE1505&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Ask me for more help.
Cheers,
Steve
May 03, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 Vista : the wireless card turns off
is ur WIFI connected thru USB ?
then ur USB is losing power...
check if ur USB setting...
go to Device Manager/USB Serial Bus/USB root hub...
go to each ports one by one....right click on each check properties...check Power Mgt tab....
remove the Tick in the box that says "Allow computer to save power'....
close Device Manager/ Shutdown and restart....
Dec 25, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 will not connect wirelesly
my laptop work well for 8 minutes and suddenly a blue screen comes up saies that there is
NMI:channel check / IOCHK
Oct 04, 2009 | Dell Inspiron 6400 Notebook
Cant connect to internet
That will be the default gateway address.
Compare the settings there, my money is on that fixing it. Otherwise it will be the DNS server Main and Secondary IP addresses.
Do you use DHCP or fixed IP's?
Apr 25, 2009 | Dell Inspiron 6400 Notebook
Inspiron 6400 detects networks but does not connect to internet
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
Apr 11, 2009 | Dell Inspiron 6400 Notebook
Wireless internet dell inspiron 6400
Things you can do to try and improve the connectivity are:
1. Update the system BIOS to the latest version
2. Update the wireless driver to the latest version (Both are available at support.dell.com)
3. Try a different channel for wireless on your router (Most default to channel 6, so try 1 or 11)
Jan 24, 2009 | Dell Inspiron 6400 Notebook
Wireless connection/will not connect
If it has been working before try the following:
Remove plug from your wireless DSL router for about 1 minute, reinsert the plug and try again.
Restart your laptop
Jan 06, 2009 | Dell Inspiron 6400 Notebook
Can't connect to internet through wireless
Go to a working computer (beg borrow or steal) and download the drivers for your model laptop from the DELL WEB site (suggest you insert your Service Tag to get the correct drivers for your model laptop), copy it to a CD or USB memory stick and then install them on your computer.
Don't forget to activate your XP license and also install SP3 (Service Pack 3 it's approx. 350Mb in size).
Dec 28, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 Notebook Logo
131 people viewed this question
Alun Cox
