Model number xca121d carrier room air conditioner,
Model number xca121d carrier room air conditioner 12000btu, dont have the install directions and we gotta put the pieces on it...how do i get the directions?
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
yalmer
  • 552 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
bobotfel
  • 236 Answers
SOURCE: Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
Actually dry and moisture setting cannot cool your room because in that sitting the temperature is limited, you have to set the control in cool or auto.. If the unit is blinking try to reset the unit by disconnecting the power supply for 10 sec.("on" & "off" the circuit breaker), and test the unit.
But if wont work the unit have some defect it may be the thermistor, low freon, or the outdoor unit have some problem. Check if the outdoor and indoor unit is clean or you to call a qualified technician for this problem.
Posted on Mar 27, 2008
boysor2933
  • 293 Answers
SOURCE: LG LWHD8000RY6 Air Conditioner Not Cooling Room
Remove the front cover of the unit to expose the cooling coil. Put the unit on and observe if there will be formation of frost (ice) on the coil. If there's frost formation, the common cause is dirty cooling coil. Have it cleaned using an alkali base coil cleaner. If the coil is clean, then the problem is the fan motor. It might be turning slow due to copper loss. Have it replaced.
Posted on May 29, 2009
What carrier product has model number 52SQA307301AA?
that is a Carrier Room Air Conditioning Model number
Jan 06, 2016 | Carrier Heating & Cooling
The control knob on my Carrier model Vision Aire window air conditioner broke. I'd like to buy a replacement know to control the fan.
Jules, without a correct Model Number (not Vision Aire, that's just a glitzey name), it's hard to steer you in the right direction on where to find the knob. If however, you can come up with a correct model number, you can go to the link below and search for it by your Model Number.
http://www.appliancefactoryparts.com/airconditioners/carrier/carrier-knobs.html
Hope this helped you.
Jul 06, 2011 | Heating & Cooling
Hi I have a Daytek 12000btu. The air con is blowing out cold air but despite having all windows and doors closed the cold air is not circulating around the room. Its only cold when you stand in front of...
air filter, cooling coil and blower wheel are full of dusty. Clean it. And also check RPM of indoor fan motor. If less replace capacitor. If rpm o.k, after clean run the unit. Thanks.
Feb 09, 2011 | Daewoo DSA-122L Air Conditioner
I have a 14.4 square metre office room, fitted with 12000btu split AC unit for cooling, will it be sufficient?
1tr could cover up area of 100 Sqft ( Nearly 10sqmtrs) 12,000BTU is 1Tr. Better you go with 1.5 Tr. Otherwise make any patrician work to short the area, if you can. Thanks.
Feb 01, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Do i need to install a jet expansion valve for the Carrier Model 40GKX casette type aircon unit? I was asking because the temperature of the room is not getting the temperature i wanted.
Before you buy, you have to calculate the heat load of your room and as well as the temp to be maintained in that room. Basing on that, there so many engineers in sales counter of every branded air conditioner to recomand you the correct model.And I hope with same expansion valve you can get required temp.
Dec 25, 2010 | Heating & Cooling
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
I am trying to find how many ton this Amana Air Command 90 is.
usually in the model number 12000btu per ton ex cplt024 2 ton 36 3ton 42 3.5 also same on compressor model number although could be less if high eff
May 11, 2009 | Heating & Cooling
ROOM SIZE
Work on around 650btu per square meter.
Mar 25, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
311 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
