Question about Peg Perego John Deere Gator HPX Ride on Toy
Gator doesn't go
Older yellow Gator will not go forward or reverse. The bed motor operates. Is there a way to troubleshoot the pedal switsh and the shifter switch assembly?
    Habit-Forming:
  • 156 Answers
I had a green gator model and replaced the switches in the shifter and that fixed the problem. I found them at
http://www.mypegperegoparts.com/switches.html
I also have called them before at 1.801.655.0800 for other help on these toys and they were very helpful
Posted on Jul 08, 2010
  • hoopsgal21 Dec 30, 2010
    Thanks for the phone # !!!!!
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You can use a multimeter and check at the pedal for 12v, id aslo check your battery and charger for the proper voltage
Posted on Apr 30, 2012
    Problem Solver:
  • 7 Answers
I think its waste, while we got these of toys, should concentrate with the warrentee..
Posted on Jul 27, 2010
My grandson's Gator runs ok in 2nd gear, but doesn't do anything in 1st or reverse.
one of your motors must be bad or unhooked, you'll have to remove the dump bed to get at the motors, then verify that they are both connected, or it could possibly be the shifter switch
Apr 28, 2012 | Peg Perego John Deere Gator HPX Ride on...
Gator goes forward in reverse and reserve in forward. Battery is hooked up correctly
there should be a wire harness on the back of the shifter to go forward and reverse try to switch it around
Apr 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
Our gator goes forward in reverse, and reverse in forward????
polarity is backwards on the motors, just switch the wires around on the motors
Apr 06, 2010 | Peg Perego John Deere Gator HPX Ride on...
Gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Mar 28, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Mar 24, 2009 | Peg Perego John Deere Gator HPX Ride on...
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Peg Perego John Deere Gator HPX Ride on Toy Logo
1,070 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
