Question about Kenmore HE3T Washer
I get an H on the washing machine what does this mean? While this is flashing i also get an F flashing
    President:
  • 1,382 Answers
The reason for "F" flash is that if your machine doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely if it's frozen or stiff replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !!
Posted on Jul 08, 2010
    Champion:
  • 274 Answers
Am not sure it may mean the hot-water is not at temp.have you sanitized the machine lately?
LG washing machine WF-T1031TP erra light flashing bE which i think means Abnormal ball sensor
light flashing means that there not sufficient water coming through the inlet.
Aug 04, 2008 | LG Washing Machines
Smeg WM72141BK LEDs flashing 4 times
E4 is water temperature probe short or interrupted.
Apr 21, 2014 | Washing Machines
Novotronic 1918 front load washing machine- not spinning 1st and 2nd rinse lights flashing
the flashing lights mean it's "disabled". You need a qualified repairman to service it further.
May 06, 2012 | Washing Machines
How to repair Beko WM8127W
my washing machine is flashing up c on i have no idea what this means will turn to what wash i wont to put it on but when i press start flashs up that
Mar 14, 2011 | Washing Machines
E1 flashing on my telman washing machine
I found my manuel. It means somethngs stuck in the pump or pipes
Dec 03, 2009 | Washing Machines
Not working
when lights flash on indesit washing machine means there is a fault with the machine you will need to tell me which ones are flasing so i can tell you what the fault is
Jun 11, 2009 | Washing Machines
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
When i start a wash the water will go into the machine it will was then stops and the lights all flash
Flashing lights mean that machine is reporting a problem. Check the user manual to see what specific flashing is about. Most likely you'll need to call a repair man.
Apr 09, 2008 | Washing Machines
Kenmore HE3T Washer Logo
57 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
