Question about Sony SDM X53 15" LCD Monitor
Unit no longer powers up. Tested with multiple power cords.
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
I am trying to locate a power cord for a alpine life sports 2000 stepper
Look at the power cord end that goes into the unit, there are multiple cords on the market that will fit, you just have to get the right end..
Jan 02, 2015 | Exercise & Fitness
I lost the power chord to the remote on my George sound system by Chestnut Hill
unfortunately it seems the George is no longer available. However, the power cord is a USB cord then you should be able to replace it by picking up a multiple USB cord kit (the one that has both the standard and mini sized cords).
May 23, 2014 | Apple Chestnut Hill Sound GEORGE Compact...
How do i reboot my 3301avr
Page 55
1 Switch off the unit and remove the AC cord from the wall
outlet. (for North America model)
Switch off the unit using the main unit‘s power switch. (for
multiple voltage model)
2 Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet. (for North America model)
Hold the following AUTO button and PCM button, and turn
the main unit‘s power switch on. (for multiple voltage model)
3 Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
Aug 05, 2010 | Denon AVR-2807 Receiver
Powers up for a few seconds then cuts out and goes dead
Make sure your extension cord can provide 13 amps or greater of current. The longer the extension cord the more current it requires to supply the 13 amps to your power washer. If your unit has a long extension cord it could pull more than the typical 15 amps used for a household circuit breaker. If you do not have an adequate circuit breaker it will continue to trip. Plug the unit directly into the power receptacle or use a larger current rated power cord and power receptacle. If the problem persists then the unit could be pulling too much current due to motor restrictions.
Jul 26, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
I need to move the power cord from floor to ceiling
I would recomend you purchase a "heavy duty" (12 guage) short extension cord for appliances. You could remove the face cover and modify the unit so the cord goes up but I don't think it will be much longer nor will it be as safe. The cord has a moulded gromet mad onto it so you may only be able to move it to the side. You would have to make a similar mount on the unit (cutting metal and plastic parts to hold the cord properly. The short HD cord will not cause any loss in the units operation,warranty or unit life.
Aug 04, 2009 | LG Art Cool LA121HNP Split System Air...
Sony LBT W5000
According to Page 46 of the LBT-W5000 Operating Instructions:
"The display stars flashing as soon as you plug in the power cord even though you haven't turned on the system (demonstration mode).
Press DISPLAY (for LBT-W5000 / W300 / XB700 / XB500) or DEMO (STANDBY) (for other models) while the system is off. If the system is in the Power Saving mode, press POWER SAVE / DEMO (STANDBY) (for LBT-W5000 / W300 / XB700 / XB500). The demonstration appears automatically the first time you plug in the power cord, or if there is a power outage lasting longer than half a day."
I tested this today, as my LBT-W5000 was in Demonstration Mode. It definitely works. The only catch is (at least on the W5000), and it's a minor one, you have to reset your clock afterwards.
May 29, 2009 | Sony LBT-W5000 Shelf System
How do you take the DC11 apart?
Unplug the unit from any power first.
To get the unit apart you have to Carefully pry off the wheels from both sides of the unit to allow access to another 4 torx screws. Use a longer flat blade screw driver and insert this between the wheel and the body of the vacum as close to the wheels center of rotation as much as possible. This should allow you open the clamshell like case. Once inside you can test the power switch and connections. My switch tested good but there is a problem with the power cord that I am trying to determine.
I am trying to replace the cord but the cord reel assembly and cord seems tighly integrated so I may end up buying the replacement power cord assembly if it is available for purchase to the general public and not only service centers. I will try the plug into the wall assembly first as it is easier to replace.
Good luck
Jan 03, 2008 | Dyson DC11 All Floors Bagless Canister...
Sony SDM X53 15" LCD Monitor Logo
15 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
