Question about KitchenAid Ovens
I have a kitchenaid kgsa906pss01 neither the oven nor the broiler will ignite. they both went out at the same time. is this an igniter problem that both should be replaced or is it something else?
2 Suggested Answers
vitg55
  • 78 Answers
SOURCE: Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 10, 2008
Kitchenaid superba oven
check the igniter for oven and change
you may have a seperate igniter for the broiler
Nov 15, 2013 | Ovens
When i set my oven to turn on, it doesn't heat up. Sometimes I get an oder of gas.
Good evening
First ,a couple of questions.Is this an electronic ignition? Most likely yes,as this problem seems to happen with E ignitions. Open broiler door,turn on oven and look inside .You should observe an orange glow appear .(Small blue flame indicates standing pilot) If yes then wait for ignition.No or partial ignition or some gas release means you need a new igniter.Very common. They do get weak. Inexpensive fix.Couple of bolts and plug.
PLEASE TURN OFF POWER TO MACHINE BEFORE SERVICE 120 volts down there.
good luck
Was this helpful?
Aug 18, 2011 | KitchenAid Ovens
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 14, 2010 | Ovens
Gas oven does not light
I called the service where the item was purchased.
You were no help at all
Dec 03, 2009 | KitchenAid Ovens
Oven won't ignite but broiler does
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 11, 2009 | Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Dec 09, 2008 | Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
Whirlpool super capacity 465 / gas oven won't light
now you say your top burners aren't lighting well either have you noticed any difference in the flame height if you turn all the burners on all the way
Jan 17, 2008 | Ovens
Ovens Logo
70 people viewed this question
Top KitchenAid Ovens Experts
ashburton
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
