Question about HP Pavilion F1703 17" LCD Monitor
Osd main menu appears in middle of screen and will not go away
    Guru:
  • 731 Answers
To unlock the OSD menu:
- If the monitor is on, press the power button to turn the monitor
off.
- Press and hold the brightness, contrast and menu keys
simultaneously.
- While holding these keys down, press Power to turn the monitor on.
- Let go of the keys.
Regards,
Riztech
Posted on Jul 08, 2010
  • 4 more comments
  • mcbeth_l Jul 08, 2010
    that puts the monitor in a standby mode power light is flashing can only stop by disconnecting power
  • Mohammed Rizwan
    Mohammed Rizwan Jul 08, 2010
    Try the below fixes
    Fix 1:
    Plug in the monitor and power it up. Hold down the Power button until you get a message saying “OSD Unlocked”. If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
    Fix 2:
    Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
    Fix 3:
    Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
    Regards,
    Riztech
    None of the three solutions solve the problem
  • Mohammed Rizwan
    Could you confirm, if you are getting message "OSD locked Out" ?
    I am not getting any message blue bos on screen say Service Menu and over it is anothe blue box that says Brightness Contrast when I hold the menu button down the box boxes go away and then return the minute i release the menu button
  • Mohammed Rizwan
    Once OSD is locked, all OSD functions including the shortcut buttons are disabled. If OSD is locked, pressing any button on the monitor directly opens the Lock OSD settings window so that you can unlock OSD by selecting the BROWSE option.
    (OR)
    The Menu button may be stuck (pressed in position) or the hardware behind the button might have become defective. We need to open the monitor
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
There is a blue lock that appears in the center of the screen
Change the OSD Lock option from ON to OFF by following these steps:
Press the Menu button on the remote or the control panel for 15 seconds to unlock the OSD menu.
When the OSD menu appears, select the Management option at the Main Menu, then select OFF at the OSD Lock option.
Select Exit to save the setting and exit the menu.
hope this helps
Aug 07, 2012 | Dell OptiPlex SX280 PC Desktop
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
A white block appears in the middle of the screen... it says" OSD lockout" occasionally it will disappear for a moment, but then returns or a large black box that has "Main Menu" at...
Fix One: Plug in the monitor and power it up. Hold down the Powerbutton until you get a message saying "OSD Unlocked". If the problem persistsafter OSD is unlocked then unplug the monitor from the wall, wait 20 secondsand try again. Fix Two: Turn on the monitor and hold down the Menu button for 10-20seconds. This should unlock the OSD. Fix Three: Turn off the monitor, press down the Menu button and thenturn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Aug 10, 2011 | HP Pavilion w22 22" LCD Monitor
A small little blue box appear in the middle of my screen with OSD locked and after 10 seconds it changes to OSD unlocked and it doesn't go away!!!
hi,
please browse the following site
I have a RAZ 3, cingular service and at the top, middle of my screen is a ..... Hi, wondering what the the blue blinking icon which what appears to be 2 small white ... I notice it after Ive had my cell off for awhile and turn it back on. ... and at the top of the screen it looks like a little box with an A in it, ...
www.askdavetaylor.com/what_do_all_the_icons_on_my_motorola_razr_v3c_phone_mean.html - Cached - Similar
May 30, 2011 | Office Equipment & Supplies
Ocd lockout
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | HP W1707 LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
The osd main menu has appeared on my hp pavilion f1703 monitor
Control Panel->System->Hardware->Device Manager->Monitor. select and uninstall. Then let Windows detect the monitor and re-install the drivers for your monitor. Do the same for the disply adapter in the Ctrl Panel.
Aug 24, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Jan 29, 2009 | Philips 190B6CB/27 19" LCD
HP Pavilion F1703 17" LCD Monitor Logo
161 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
