Question about Boating
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE AND STOPS AT 9000 rpm
    Champion:
  • 274 Answers
Did you mean 900 cause 9000 is overrived and the engine may be blown
Posted on Jul 08, 2010
There is black mold (lots) in the undercarriage of my wave runner. How do I get rid if it - it's under the motor, very hard to get at ????
try using a mold destroyer agent ( bleach, mold remover , chlorine etc from a hardware /paint shop)
spray it in , let it sit for a few minutes then hose it out
repeat in a few days as mold spores will regrow
talk with a boat shop for other ideas
Sep 17, 2016 | Yamaha 2010 WaveRunner FX Cruiser HO
It Runs but has very little power,quits often,if you give it to much throttle it bogs down
Robert, First try new plugs, check fuel filter, sounds like it could be carburetor/injector issue, dirt,plugged jet, etc. Remove and clean/rebuild carb./injector.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
XLT1200 Bogs down
Thread 2004 FX HO ECU Problem
Waverunner Loses Power and Wont go Above 35 mph Solution
https://answers.yahoo.com/question/index?qid=20080525091900AATkgJh
May 23, 2016 | Yamaha 2004 WaveRunner Superjet Base
Why does yamaha waverunner fx cruiser ho not run in lake but will run hooked to water hose
Sounds like you have a bad stator. It may be producing enough spark to start the motor, but under a load (as in the water) it simply can not supply the amount of spark needed. Sometimes when a stator is tested on a ohms meter it may test good, but still be defective do to the load it will come in contact with when put in the water.
Jun 29, 2014 | Yamaha 12V Air Pump
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Waverunner is abnormally slow accelerating initially, but will finally get up to normal speed
Pull your air filter out and also replace plugs. Overtime the filter will become saturated with oil and believe it or not the plugs can cause about a 10 mph drop if there going bad. But make sure your pump and impeller are not damaged also
Sep 18, 2013 | Yamaha 2004 WaveRunner FX Cruiser
Got my 2009 Yamaha FX sho waverunner under water, drained the water from the hull and tried to start it. Turned over 5 or 6 times and stopped. Pulled the air filter out and of course had water in it....
remove all sparkplugs and hold full throttle and crank over several times to get water out of cylinders ! have a jump pack ready as battery will die ! use carb cleaner on the plugs each time you try to run after this , hope this has only just happened as internal damage might already started ! if all ok check the engine oil also as water normally gets in after this problem ! if oil is milky then change oil several times , run for 15min on hose each change until oil normal colour ! then you must take for a run for an hour to help dry it out !
Mar 19, 2013 | Yamaha 2009 WaveRunner FX Cruiser SHO
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Jul 28, 2009 | Yamaha 12V Air Pump
Boating Logo
182 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
