Question about Frigidaire FRT18KB2CW Top Freezer Refrigerator
Collected water in evaporator pan does not
The forementoned Fridgidaire model has an evaporator pan that sits atop the condenser. Collected water in evaporator pan does not evaporate enough. Too much water collects and constantly pours on to floor. Can the drip tube be safely connected to an extension tube emptying directly to a floor drain, and therefore bypass the collection pan?
  • 4,793 Answers
You obviously live in a high humidity area.(or you are putting warm/uncovered food inside) but the answer is yes,or you could collect the water to use on you indoor plants.........better than tap water...
Posted on Jul 08, 2010
Water on the bottom inside the fridge
Hello Simon Kaloussdian,
I dearly love refrigerators... if for nothing else... they sit
for decades working their hearts out... usually to never be given a second thought .
I'm looking at your 280 day old Daewoo top freezer
report... (only by researching your history)...
INFO: Country, features, history & model number?
So... no door service... water/ice service ELIMINATES
a lot of concerns... You are basically looking at
a DEFROST, drainage or air-leak problem...
From your previous issue...
you know the EVAPORATOR collects ice...
Your DEFROST circuit... routinely removes it...
Or should:
There are only 3 defrost elements:
- TIMER/Control (clock or Circuit board)
- Defrost thermostat (restrains EVAP heater)
- Defrost heater (warms.... only)
A clear drain to the DRAIN-PAN allows the moisture to be externally collected & removed (usually evaporative)...
ASSUMING all your door gaskets are good... you must have a blocked drain (I'm suspecting a clogged EVAPORATOR PAN).
Usually a dose of warm (only: not hot) soapy water
is enough to get the drain flushed out...
Else
fit a soda straw (or flex tube) to the bottom of the
drain tube and blow up...
Working FANS and clean condensers are CRITICAL to satisfactory cooling.
FIND YOUR original parts list / owners manual
and
Comment me back if you want to discuss...
I'm here daily.
Carnac the Magnificent
Apr 20, 2017 | Refrigerators
In garage/works perfectly/slow leak coming from an insulated hose that goes directly into the bottom of the freezer itself.
The hose coming from the bottom of the freezer is draining the melted water produced during the automatic defrost cycle. Usually the water is collected in a pan somewhere around the hot compressor motor so the heat can evaporate the water.
The hot copper tube by the compressor is the high pressure tube going to the condenser. The other tube going to the compressor is the return line from the evaporator and, after normal operation, is cold to the touch. It is this cold refrigerant returning to the compressor that cools the motor.
Aug 19, 2015 | Refrigerators
Where is the evaporator tray?
if not directly under the evaporator, often the condensate from the evaporator is led via a tube to a tray that sits atop or around the compressor and evaporates from compressor heat.
Jul 23, 2015 | Refrigerators
Water does not evaporate why?
That air conditioner has a cooling coil that drips water into a formed plastic pan at the bottom that the coil sits in. The condenser sits in a pan similar to the pan previously mentioned. The pans are connected by a tube that allows the cooling coil water to find its way to the outside area under the condenser. The condenser fan outside has a ring attached to the end of the blades called a sling ring. As the fan spins it picks the water up and "slings" the water against the condenser thus getting rid of the water through evaporation and giving the air conditioner an additional 13 percent more capacity. If you drill drain holes I have seen units quit working because that additional capacity is engineered into heat rejection. Hope I helped good luck.
Oct 09, 2014 | Amana AH123E35AXAA 11,600 BTU Room Air...
Fridgidaire ffht1817lw8 noisy operation
Good Afternoon John, thank you for your post! Your new high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become a common hum in your home. This noise also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable.
Listed below are descriptions of some of the most common sounds you may hear, and what is causing them:
A. Evaporator: The flow of refrigerant through the evaporator may create a boiling or gurgling sound.
B. Evaporator Fan: You may hear air being forced through the refrigerator by the evaporator fan.
C. Defrost Heater: During defrost cycles, water dripping onto the defrost heater may cause a hissing or sizzling sound. After defrosting, a popping sound may occur.
D. Automatic Ice Maker: If your refrigerator is equipped with an automatic ice maker, you will hear ice cubes falling into the ice bin.
E. Cold Control & Defrost Timer or Automatic Defrost Control: These parts can produce a snapping or clicking sound when turning the refrigerator on and off. The timer also produces sounds similar to an electric clock.
F. Condenser Fan: If condenser coils are located underneath your refrigerator you have a condenser fan. You may hear air being forced through the condenser by the condenser fan.
G. Compressor: Modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound.
H. Water Valve: If your refrigerator is equipped with an automatic ice maker, you will hear a buzzing sound as the water valve opens to fill the ice maker during each cycle.
I. Drain Pan (Non-removable): You may hear water running into the drain pan during the defrost cycle. The drain pan will be located on top of the compressor for air-cooled condensers (black coils on back of refrigerator).
I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Aug 27, 2013 | Frigidaire FRS3R5EMB Side by Side...
My fridge freezer leaks water every two to three days any ideas why?
Actually, on most Frost Free refrigerators (which are most refrigerators manufactured in the last 25 years) there should be a small "pan" underneath that "collects" condensate. This is a normal process as, every so many hours, a small heater comes on inside the freezer to "melt away" any of the accumulated frost. This frost melts and runs down a tube and then is collected underneath the refrigerator. The external fan underneath the refrigerator causes the condensate to eventually evaporate into the room air. You might be, either in a very humid environment and it can't evaporate fast enough, or more likely that you have a missing pan to collect the condensate. If it is missing, you might get lucky with finding a small "cookie sheet" that might fit underneath. Be careful though. You don't want to touch, AT ALL, any of the coils (looks like radiator screens) underneath, or the fan blades. Best bet if you are missing the condensate pan is probably to get your model number and search for parts at a local appliance parts store or online.
Dec 15, 2011 | Maytag Refrigerators
Water is draining into a pan under the refrigerator, once in a while
When the fridge defrosts, the water (melted ice) is collected into the water pan. Empty it when the fridge compressor is ON.
Oct 07, 2009 | Kenmore Refrigerators
Where is the water pan located?
your evaporator coil sits in the water pan This pan is installed at the bottom of the evaporator coil to prevent condensate water from damaging the area the furnance sits. If you open your furnance and look where you put the a/c filter the coil should be right here. If you look at where the coil rests there is you "water Pan" Good Luck hope this helped
Dave
Sep 17, 2009 | Heating & Cooling
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Frigidaire FRT18KB2CW Top Freezer Refrigerator Logo
382 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
