Question about Whirlpool Dryers
Dryer not heating.
My whirlpool dryer LER5644ANO will not heat. It runs fine but quit heating. Does anyone have a parts list? The bottom thermal is open part #3389946 L350 F.
  • 10,319 Answers
First clean out the exhaust vent tubing entirely and then try it. It may heat up very hot if thoroughly cleaned out. A moister sensor detects any lint build up and put the burner into a check mode that prevents home fires in the exhaust vents
Posted on Jul 08, 2010
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Dryer still runs it just isn't getting warm
The heating element is wired in series with a thermal cut-off and a high-limit thermostat both located on the heater housing.The thermal cut-off blows open when the high-limit thermostat fails to cycle off in order to regulate the heating element temperature. When the thermal cut-off is blown, power to the element is cut-off and the dryer will not heat. Replacing both thermal cut-off and the high-limit thermostat if the former is indeed blown. Click on the links below for the troubleshooting and repair details.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Front Bottom Panel) Running But Not Heating
Jun 18, 2011 | Whirlpool Dryers
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
Dryer wont heat up already replaced thermal fuse
You gas coils are probably old and weak. check this out
Gas dryer works and quits
Apr 11, 2009 | Whirlpool Dryers
Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Why won't my dryer turn on?
you eather have a broke door switch or a blown thermal fuse you can check the door sitch just press and releace the switch it sould click it the tab i not broken if it is broken or you don't hear it click just replace the door switch.if the switch is good you need to replace the thermal fuse it is located on the back of the dryer. unplug the dryer remove the back cover at the bottom the is a small white fuse on the blower housing it has two blue wires pluged into it remove the one screw and wires replse the fuse reconect wires put back cover on plug in dryer and test.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer runs fine, does not heat?
Remove the back and on the right side is the heater assembly. Attached to this assembly is a safety thermal fuse at the top and a heat limiter thermostat at the bottom. The fuse, thermostat or heater may have failed. The MOST common reason for any of these parts to fail is a clogged or restricted exhaust. Be sure to clean/inspect the exhaust system or the dryer will fail again.
Dec 25, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer model LE5795XPWO
does it run ..if it runs and do not heat check thermal fuse.if it dont run check lid switch..alway unplug first
Dec 10, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer with no heat
Is the igniter glowing yellow? Look inside the pilot access hole and see if it lights up. If it lights up then goes off, it may be the thermal fuse. Once this blows, it has to be replaced. There are pictures all over the internet on the location of this part.
Good luck.
Apr 16, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
211 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
