Question about Canon imageCLASS D880 All-In-One Laser Printer
Black line in auto feed
Black line appears on all documents that are feed throught the auto feed. what's the fix?
  • 2,016 Answers
If you lift the scanner cover, you should see an area on the right end of the platen glass marked at the edge with arrows as Read Area. This is the area used when documents are scanned through the auto feed. Make sure that the glass is completely clean in this area, as any dirt will show up as a line on the copied image.
Posted on Apr 18, 2008
My copies come out rippled at the bottom of the paper. Samsung black and white laser printer
You should try feeding one sheet at a time and make sure u are using paper that is compatible
Oct 02, 2016 | Samsung Office Equipment & Supplies
I get a black line when scanning, ( not when printing)how do i fix it
This is commonly caused by a mark on the scanner plate. If you place your document to scan on the scanner plate (Lift the lid and place it on the glass plate) and scan or copy the document does it come out clean? If you feed the document through the Auto Document Feeder doe the line appear?
If when place on the plate it is clean but fed through the ADF there is a line, then when you lift the lid on the scanner you will see a narrow glass plate at the end (Normally the left end) of the scanner plate. Give this glass a clean and your mark will go away.
If the scan or copy is lined when using the Flatbed scanner and the ADF then the problem will be in the scanner lamp which will be probably uneconomical to fix.
Oct 09, 2014 | Brother MFC 6490CW InkJet Printer
Black vertical lines when scanning on canon mx420
the ocr sensor in the ADF needs to be replaced, I would recommend replacing the whole ADF as a whole.
Aug 10, 2012 | Office Equipment & Supplies
When scanning a red line appears on my scnned copy and runs throught the document
lift the top as if I were going to scan or copy something. I checked the glass. On the far left is a separate glass area. This is what the feeder uses to actually copy or scan a document. This had a smudge on it. I cleaned the glass and it was fixed.
Jul 27, 2011 | Brother MFC 490cw Color Inkjet...
I recently installed a new laser cartridge. Shortly after, when copying a document, two black vertical lines began appearing on the copy. What is the fix for this? The black lines do not appear when...
Clean the scanner glass. When I had that problem, I set a copy with lines on it in the scanner feed to see where the problem was, and when I lightly ran my finger on the glass over where the lines were, I could feel two small bumps. I just scraped them off with my fingernail, but here is the HP solution for cleaning your scanner glass:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00062196
Aug 24, 2010 | HP LaserJet 3015 All-In-One Printer
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
May 20, 2010 | Brother MFC-7440N Laser Printer
My Sharp Al-1642cs is leaving a black stripe on the paper when coping.
Does the line appear when you copy from the glass? Or is it Just the document feeder. If it is just throught the doc feeder then you have to clean the **** glass next to the main glass. It only takes a small dot to make a line. Hope this helps. Have a nice day.
Apr 29, 2009 | Sharp AL-1642CS Copier
Two black lines printed on sent faxes
Clean the glass onder the cover where the document feeds in.
Apr 24, 2009 | Canon FAX-L1000 Plain Paper Laser
Black line on scanned document
Please clean the glass with Isopropyl alcohol. Dont use solvents.
S. Mohan
Mar 27, 2009 | Canon DR-1210C Scanner
1/8 black lines on Sharp AL-1631 copier
Have you cleaned the narrow glass next to the platen where the originals are scanned across when using the auto feeder?
Feb 17, 2009 | Sharp AL 1631 Copier
Canon imageCLASS D880 All-In-One Laser Printer Logo
953 people viewed this question
old marine
old marine
