Question about Magic Chef Ovens
We have a Magic Chef glass top electric oven and the past few nights it has been beeping and showing a F-1 on stove top area
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F1 error indicates that the touchpad membrane is defective. To resolve this issue you’ll have to disconnect the ribbon strip: after disconnecting if there is no fault code then the membrane should be replaced, if the fault code still appears then the control board should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
I have a magic chef S68-3cxw electric stove/oven. It is flashing f2 can anyone advise what F 2 stands for
Hi, the F2 code on the Magic Chef Oven implies that the Oven temperature is too hot.
The solution is to replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness...
Oct 09, 2010 | Magic Chef Ovens
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
F 1 beeping on Magic Chef oven ?
The F1 code is a defect touch pad or membrane
May 01, 2009 | Magic Chef Ovens
I just got a used stove and its a single magic chef eletric stove. when I plug it up it will beep and on the display screen it says L1. what does that mean. im not sure what model it is though. its a older...
Usually L1 is a code for power on. So try to clear it by pushing enter or clear and see if it helps.
Please rate me accordingly if this helps and good luck.
Mar 13, 2009 | Magic Chef 9512 Electric Single Oven
My magic chef oven will not heat in the oven or on the stove top after the electricity was shut off for a few hours. what could be the problem?
If it has a timer, make sure it is set to manual,and not flashing auto.
In the auto mode the oven will not work.
Plz rate this solutioin.
Thanks.
Dec 27, 2008 | Magic Chef 9512 Electric Single Oven
Contune to beep F-1 flashes
f-1 codes are usually a temperature issue. you should try ohm'ing out the temperature probe you should have about 1260 ohms. if you are off by 40 ohms then replace the temperature probe. if it is close then you may have a bad control.
Dec 01, 2008 | Magic Chef Ovens
MAGIC CHEF TIME SAVOR GLASS TOP
Hi - Please post the model number of you appliance, it will look something like CEC1536.
Thanks.
Jul 02, 2008 | Magic Chef 9512 Electric Single Oven
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
141 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
