Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Forgot security code
Is it possible to reset to default and enable router in non-secure mode?
  • 550 Answers
Yes you can reset the router and it will come back to the factory default settings.
now you can connect the computer to the router. open the setup page of the router and setup the router manually without the CD. if you want to secure the network. you can do that also.
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Click Here
for step by step instructions
Posted on Jul 08, 2010
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Set up security
If you know the default username and password then you can login after reset the router. Reset the router using reset button. To get manual you can visit router manufacturer website.
If you want to set security then you can do the following steps:
->Change Default Administrator Passwords (and Usernames)
->Turn on (Compatible) WPA / WEP Encryption
->Change the Default SSID
->Enable MAC Address Filtering
->Disable SSID Broadcast
->Do Not Auto-Connect to Open Wi-Fi Networks
->Assign Static IP Addresses to Devices
->Enable Firewalls On Each Computer and the Router
->Position the Router or Access Point Safely
->Turn Off the Network During Extended Periods of Non-Use
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/wireless-router-support/
Nov 08, 2012 | Computers & Internet
Reverted to factory default, typed in router name and wap password, but cannot acces, it goes to dlink
you need to reconfigure the wireless settings since you reset your router to factory defaults.
login to your router with admin/admin as the login/password
click on wireless settings and enable wireless security mode to wpa and type in the wireless password you wish to setup.
all wireless devices will need to be setup to your new router settings.
May 22, 2011 | D-Link DIR-615 Wireless Router
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Set up a non wep password
Hi Friend,
Please follow the steps;
1.Open the router page(192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.Click Wireless and then fill the sections as mentioned:
Wireless-Enabled
Wireless Netowrk Name-As per your choice
Wireless Channel-6-2.442GHz
Wireless SSID broadcast-Enabled and click Save settings
4.Click Wireless Security and fill the sections
Wireless Security-Enabled
Security Mode-WPA pres-shared key (as you want non wep password)
WPA Algorithm-TKIP
WPA Shared key-Minimum 8 and maximum 64 digit password
Group Key Renewal-3600 and click save settings
Turn off the router for 30 seconds and turn it on after that. Now you have a non wep secured network
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
My WRT300N Linksys router shows all lights, I've hit the reset button onece, but I can not get online without plugging the cable directly into my computer.
Since you hit the reset button on the router, it will go back to default settings.
By default, the SSID is linksys and the wireless security is disabled.
So on the wireless network connections on your computer, you should see linksys and then just connect to it.
However, it is advisable to change the default SSID and to enable the wireless security.
Follow this link to change the SSID.
Follow this link to enable wireless security.
Dec 30, 2009 | Linksys WRT300N Wireless Router
I forgot my security enabled password
Reset the router to factory defaults. Look for a hole/button on the router near which it says RESET. If a button, press it; if a hole, use a blunt paper clip to insert in the hole and press gently. Router will be reset to factory default and you will have to reconfigure it to secure your network.
Hope it helps.
Aug 30, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
D-Link 514 model
the key number will be listed in the router settings as you must have security enabled in the router, if you cannot find it then simply reset the router at the rear of the unit and start again as there will be no security key number and all the settings will be back to factory default.
Oct 23, 2007 | D-Link DI 514 Wireless Router (DI-514)
Renaming Linksys BEFSX41 router and securing it.
It sound to me that you have a wireless card in your laptop and you are picking up your neighbors wireless router!!!! which has no SSID set, thus "default" and has no encryption set, thus "unsecured network". Turn off your wireless adapter The only security on a Non-Wireless router is turning on the firewall. It should be enabled by default. The other thing would be to change the password on your router, but since you do not have a wireless router, then it is pointless, unless you do not want someone in your house to access the router settings and make changes. Ever then, if someone in your house that is physically connected to the router with a "cable" could alway walk to the router and stick a pin in the the "reset" hole in the back of the router to reset wipe any changes that was made, so a password is pointless as far as I am concerned for non-wirelss routers. open your browser and type http://192.168.1.1 Admin User name: Leave it blank Password: admin Once you login you can change your password if you like.
Aug 23, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
74 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
