Question about Amana DLW330RA Top Load Washer
Machine washes, but will not spin at end of cycle. Clothes remain soaked. How do you fix this?
    Champion:
  • 274 Answers
Try moving clothes around,It may be unbalanced
Posted on Jul 08, 2010
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
Water coming on after spin cycle
Change your belt or seal of tank of machine.
Dec 18, 2013 | Maytag MVWC5ESXW Washer
My clothes are soak and wet after the spinning cycle ends
Could be a gearcase problem or a motor coupler problem or a clutch problem .Best off to call a reputable service company such as Sears.
Feb 06, 2010 | Washing Machines
Machine spins and drains but clothes r still soaked
checking the hose is good but also check to see if the hose end is above the pumping ability of the washing machine
Sep 11, 2009 | Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch Nexxt 800 washer won't drain clothes fully
There is not a Spin Only Cycle BUT there is a REFRESH cycle that will take about 10 minutes.
Sometimes when the load is unbalanced and the machine can not balance the load by itself, the clothes will remain soaked. To avoid this, make sure you always have a balance of small and large things and when loading your machine, do not shove the items in so they ball up.
Dec 27, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 06, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Amana DLW330RA Top Load Washer Logo
67 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
