Question about Toshiba Satellite A105-S4004 Notebook
My screen has horizontal lines across half of the screen. I hooked up to a external monitor and it worked fine. What is the problem?
    Scholar:
  • 96 Answers
It would physically be in the LCD screen of your computer. If the monitor is working fine therefore there is nothing wrong with the video processing output or the drivers in the operating system. It would be in internal crack on the LCD or a loose connection with the LCD screen and the motherboard.
Its best to have your laptop checked by a service technician and dont just disassemble it by yourself to prevent accidents. Worst case is that the LCD needs to be replaced if really found cracked/defective.
Hope this helps.
Posted on Jul 08, 2010
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Horizontal lines across HP laptop TE11HC screen - faulty screen?
If shown during the boot up process then you have a physical damaged screen.
Sep 18, 2014 | HEWLETT-PACKARD Computers & Internet
Hey I got an IBM T42. It boots fine when its clear but after that it horizontal lines being to appear througout the scree.
Either you can hook up an external monitor or access BIOS setup (Basic Input/Output System) to replicate if the horizontal line appears. This step will check if the problem is with the video card or the LCD.
If you get the horizontal line on the BIOS or never get it on the external monitor, then surely the LCD screen is beginning to fail. You need to reinsert and/or replace the LCD inverter or LCD itself.
However, if you see the horizontal lines on the external monitor but not on the BIOS, try to update the video driver. If this will not resolve the issue, you need to replace the video card or the motherboard of your laptop.
Hope this helps.
Jun 06, 2011 | IBM ThinkPad T30 2366 Notebook
I have a horizontal white line going straight across my laptop, and I only got it a few days ago. Is there anyway that I can sort this out myself. Thanks x
Hook a external monitor to the video output on the back of the laptop, if it works! you have a laptop screen issue, possibly caused by a loose video cable that connects from the motherboard to the LCD screen, if the monitor has the same problem it is a motherboard issue. Doing anything to the laptop "dis-assembly" will void the warranty, best to take it back for exchange.
Jan 06, 2011 | Compaq Presario M2000 Notebook
I have a insprion 1545 that half of the screen is white with vertical lines on a white back ground. The other half is fine but can only view the left half of the screen. I hooked it to an external monitor...
It is a screen problem. You have to replace the LCD. It is either cracked or the electronics of the LCD is faulty. Find the part number on the back of the LCD and look for it on ebay.
Aug 08, 2010 | Dell Inspiron 1545 Notebook
A line appeared in the middle of the screen and has expanded and now the botttom half of the screen has two horizontal bars of vertical lines instead of the bottom half ot the display. Recently had new...
Try to plugged in external monitor to your computer. If you did not experienced this problem using the external monitor then this is not a mainboard issue. This could be an LCD issue. You need to call the manufacturers tech support department and have your computer repaired. Same goes also if you experienced same problem using external monitor. You still need to call dell tech support department for mainboard replacement.
Jun 13, 2010 | Dell Inspiron 1525 Notebook
Periodically the screen is captured by horizontal lines completely across the screen. Cannot access programs or even shut down properly. Any suggestions. Presario 700 laptop using Windows Vista. Thanks
This issue is due to the malfunctioning of the screen or due to any other internal hardware malfunctioning of the notebook.
To further isolate the issue, I request you to connect the external monitor and check.
Once after connecting the external monitor, please tsp Fn+F3 Switch between the display and external monitor in the following order:
Display
External monitor
Display and external monitor
If the external display is fine then the issue either could be due the malfunctioning of the display cable connector between the screen of the notebook and motherboard or due to the malfunctioning of the screen.
As this the hardware issue, Please contact the nearest repair center to get it resolved.
May 29, 2010 | Compaq Presario 700 470024-192 Notebook
LG F700P monitor black out on top half, horizontal white line
Sounds like your monitor or graphics card may be going bad.
Dec 07, 2008 | Computers & Internet
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
291 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
