Question about Maytag Neptune MDG5500AW Gas Dryer
PF reading - wont run when hit start/pause pad
You may just need to reset the dryer. Try holding down the Start button for a couple of seconds to reset it.
Posted on Jul 22, 2010
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerPF reading - wont run when hit start/pause pad - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turningPF reading - wont run when hit start/pause pad - 2_bing.gif
Dryer2_binPF reading - wont run when hit start/pause pad - 2_bing.gifss= Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 12, 2010
What is PF error code?
"PF" flashes to indicate that a power failure occurred while the drier was running. Press HOLD TO START to continue the cycle or press OFF/PAUSE to clear the display.
Feb 15, 2011 | Whirlpool RBS305PDS Electric Single Oven
What do you do when PF is one the screen
PF Power failure PF flashes to indicate that a power failure occurred while the dryer was running. Press Start to continue the cycle, or press Pause/Cancel to clear the display.
Nov 25, 2010 | Whirlpool Ovens
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Getting code PF, resetting breaker did not fix the problem. Dryer model Aeq6000es2.
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
The dryer will not turn on its flashing pf
Apr 15, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool duet gas dryer PF error will not reset as per manuals
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Pf and of codes comming up on screen
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Dryer
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Kenmore 82836 Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
167 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
