Question about AMT Datasouth Aries MK238 Weapon Sight
Amt mk238 when I changed the battery and turn it
Amt mk238 when I changed the battery and turn it on nothing. I hear high frequency noise. No image no green image at all. I see no change from off to on.
I have an Aries mk 208/230? night vision sight that's been sitting in the closet for several years. I put the batteries in it and it failed to work. I bought a new battery for it and it still does not...
As you probably know that internal electronic are manufactured in Russia. I just repair an ATN MK238. Verything from the image intensifier tube to power supply was shot. I managed to round up 1 gen green Russian image tube, but the ccfl inverter, tolorid coil, voltage multiplier I had to manufactured them. Sorry, wish that I could be more help. stewbison
Aug 09, 2011 | ATN American Technologies Network Aries...
Put in battery and light comes on but nothing happens, i have a aries mk 238
Jeepers! I have work on these ATN MK238 before. All internal electronic are made in Russia. There are two major problem with them. Image intensifier tube goes lights out, the ccfl inver, coil and voltage multiplier are seal in dielectric jell and epoxy. can't work of them. I can work on them, but I am not. Who ever work on it will need to install a new image tube, manufacture ccfl inverter, fine a coil and manufacture voltage multiplie and get the correct cathode ingnitor voltage, hard.
Sorry, I wish you all the luck. They one more option send it ATN and before you send it call ask what the price will be, and get the guys name or record it. stewbison
Jun 07, 2011 | AMT Datasouth Aries MK238 Weapon Sight
Lens diagram aries 238
Hi, the objective lens on this ATN MK238. Now these lenses are Russian Optics and they manufacture very good to excellent optics. Take the lens to a camera shop, if they can fix it, then they will know who will. If you send it to ATN they just throw away your lens and replace it with a new lens. If you are going to replace the lens then up grade to 90mm to 100mm lens, OK. stewbsion
May 09, 2011 | AMT Datasouth Aries MK238 Weapon Sight
There is not picture its just vioce
Battery OK, IR light up, no green image on the intensifier image tube, correct! What type of voices are you hearing? Give ATN Aries 390 two Zolof and wait two day, just kidding!!! The noise is a crackling, high freqencey hum, popping, etc. Also remove the eye lens, it screw off, then remove the scope to someplace where it semi dark. Turn it on and observe the 18mm white plate and see if it turn green---no green---no look see---no image intensifier tube, it dead that is the mage tube. stewbison.
Mar 15, 2011 | ATN Aries 390 Paladin Weapon Sight
Power light turns on, Infra red illuminator works, cant see anything in scope. Reticule doesnt light up and no vision through optics. New battery etc.
Hello, bad image intensifier tube and possible ccfl with it coil. Major repair on MK238 scope. I think they make a generation 2 tube for this scope like 350,360,390, and 410. Call AT ATN. stewbison
Mar 04, 2011 | AMT Datasouth Aries MK238 Weapon Sight
There is a white noise hiss after every sound that comes through the headphones.The sound decays over approx 1.5 seconds. Have tried moving the base around the room, spent $$$ on high quality connection...
Maybe changing channels will do the trick. The noise your hearing is like a distortion of frequency from a nearby device that is using the same frequency the headphones uses.
Oct 13, 2010 | Sony MDR-RF970RK Headphones
Crate TX50 DB has noisy DSP circuit when rotating the DSP pot!
When you are changing the DSP effect on the fly, static or noise is NORMAL !!! The DSP is changing the data and having to recalculate on the fly and doesn't mute itself while doing so which results in "garbage sounds out".
The bypass setting should NOT get any tone UNLESS you have feedback going on. If your guitar can "hear" the speakers in the amp, the strings can vibrate and get feedback going.
Unplug the guitar and see if high freq tone is still there on bypass. If the tone is in the musical range, then there is a problem if nothing is plugged in. If it is a VERY weak, very high frequency tone, this may be the digitizing noise from the DSP. On bypass, the audio is likely to still go through the DSP, just not be modified by it.
May 03, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
if the eye tube is not lighting up its likley to be the censor burnd out or the tube is broken,,, dont use it in full day light,,
Nov 17, 2009 | AMT Datasouth Aries MK238 Weapon Sight
Amt aries mk238 model#500433
I have a Amt aries 208 I have changed the battery but i cant get to do any thing . and i have lost all of the manuals can you help.Ed.
Nov 13, 2007 | AMT Datasouth Aries MK238 Weapon Sight
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
AMT Datasouth Aries MK238 Weapon Sight Logo
Top AMT Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an AMT Optic Expert? Answer questions, earn points and help others
