Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Kyocera km-3530 printer
My printer makes a funny noise every time i turn it on?
If the noise starts when you power on the machine(within2-10sec.) it could be a venting fan or the polygon motor.If the noise starts when the machine warms up it could be the fusing unit or the imaging unit. To test the polygon motor press 10871087select sim.100 and choose laser motor on.(ON is pressing start key).This is one easy step to locate the noise.To exit the simulation press3 times the stop/clear key,then 001and start.To test the fan just listen carefully on the left side of the copier.The fusing and imaging unit tests are a little dificult to explain since they require to operate the machine with open doors and bypassed switches.(But try to run sim.030 to check the motors indivintualy.Enter with 10871087 then030 then start then choose main motor and listen for the noise.Then exit by pressing 3 times the stop/clear key and 001 and start key).PLEASE don't try any other sim. codes by yourself since you will damage either quality or functionallity.
Your local service can surely see what the problem is and offer you a better solution.
Posted on Apr 28, 2008
    New Friend:
  • 48 Answers
Kind of hard to diagnose this but I would recommend that you call a dealer for service. How long has the printer made the noise? It could be a sign that something is in need of repair. Also, try to figure out where the noise is coming from. This may help to determine what the exact problem is.
Sorry I couldn't be more specific.
Henry
What type of corona wire is used on Kyocera products: FS-9520, KM-4035, KM-3530, and KM-C2520. Is it 60 Micron Oxidized?
The service manual does not specify but you will probably be ok with tungsten or oxidized. If the copies look bad with one try the other. The main charge is replaced as a whole charge assembly so I can't say that I have had to restring one.
Jul 13, 2011 | Kyocera CS-4035 Copier
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Kyocera KM-2530 printer displays "Attach Finisher." It was working until we moved it recently. Checked all cords and rebooted several times to no avail. Couldn't see any push rods or buttons that need...
on the copier metal bracket that finisher attaches far end or front ull see a metal pin that sticks out.
That pin goes in to the finisher white plastic hole.Inside that hole there is a switch that tells the copier the finisher is attached.
Oct 07, 2010 | Kyocera RI-3530 Black and White Copier
System error C4200 on kyocera 3530 printer
try doing a reset... with the copy screen on press 10871087 then when screen changes enter 906 then press enter then start then enter... if that fixes it run to the store and get you a nice expensive surge protector... if that does not fix it then your main board is fried...
Jun 05, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
Copier giving error
Defective Optical Laser Unit or main board. Is it making noise?
If so, it is the laser unit.
And that is more likely than the main board.
Sep 06, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
438 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
