Question about Eagle Fisheasy 250ds Fishfinder
I'm looking for a transducer for an eagle ultra portable.Transducer # PT-WS wide angle.
5 Suggested Answers
dnewcombe1
  • 1564 Answers
SOURCE: I have an Eagle Fisheasy fish finder & need to replace transducer
You can find out which one is serving the device you wish to repair by waving a small spade or wide metal object about a foot from each of the existing transducers and have someone else monitoring the insruments on the concole.
Posted on Sep 07, 2009
marked
  • 6487 Answers
SOURCE: I need a manual for a Eagle Fish Mark 320
You can download the user manual from this links.
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
http://www.retrevo.com/support/Eagle-320-manual/id/517ci954/t/2/
Posted on Aug 22, 2010
  • 3 Answers
SOURCE: connecting two displays from the eagle cuda 350
Do you have a 2 to 1 splitter?
Posted on Feb 06, 2011
paul4265
  • 592 Answers
SOURCE: I am replacing a Eagle Intellimap gps and eagle
Hi, Charlie!
I checked it out, and it turns out you can use the transducer of off your old 128 model.
Just unplug it from your current model, and plug it back into your EFE 480.
What I like about these newer fish finders is the fact that it also has gps built in to it, along with the maps for all of the USA, and the fact that it has a memory card slot, so that you can download new maps onto a memory card, pop it into the machine, and then it will update the maps !
Sure beats the old days where you had to send the unit in to a tech to have them install map updates.
Som yes, you can use the old one, and it should work with no problems.
Good luck to ya, and catch a big one for me !
Posted on Feb 14, 2011
Can I wire it together?
The impedance match most likely won't. I advice you not to attempt. Replace with matching Eagle model transducer.
Jan 09, 2016 | Eagle Boating
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
Let me know how you make out....Guru....Saailer
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
I've purchased an Eagle 320 fishfinder 2 years ago and I've had to replace my transducer twice. Every time I'm out fishing lakers in 50 to 100 feet of water, I keep loosing the bottom mark and...
I have never heard of Eagle Fishfinders, but I would be inclined to package it up and send it back to them for checking under warranty, with a fault that should never happen. The brand leaders are Lowrance and Humminbird, with Garmin in 3rd place.
I have a Humminbird 998HD with Side Imaging. I had a 798SI before that and never a problem. the 998 cost me nearly 2 grand Canadian and is used on Lake Ontario, twice a week every week from May to October, and has been faultless. The 798 was used from 2008 to 2014 and also faultless. I think you have a 'Friday Special'.
Mar 14, 2017 | Eagle Fishmark 320 Portable Fishfinder
Water temp is not working can that be fixed?
Double check you have a good connection from the transducer data cable to the back of the display unit and that the pins are not corroded or anything similar. If the temp has never worked at all, it may be because the transducer you are using doesnt have a temperature sensor onboard and you will need to get one that does have this feature. If it did work previously and you checked the pins/connection (as per above) then the transducer is faulty or has developed a fault. There is no real easy fix and it will most likely be far cheaper just to buy a new transducer than to have the current one repaired by Eagle. I think new trasnducers are about $60-$70.
Mar 30, 2010 | Eagle Fishmark 320 Portable Fishfinder
Sonar does not appear to work - not picking up depths or bottom structure. All other functions look good.
This problem is most likely linked with your transducer.
1. Check your transducer cable and make sure the plug terminals are clean, as well as the plug on the back of the unit.
2. Make sure the transducer cable is plugged in correctly and securely.
3. Make sure the transducer is in the water and mounted according to the directions, parallel to the bottom of the boat
4. Turn the unit on while the boat is in the water, but with the engine OFF.
IF it works when the engine is off, but vanishes when the engine is on, you may be having electrical interference.
IF it works when the engine is running, but vanishes when the boat is moving, it is a turbulence problem. Move the transducer.
IF it does not work at all, try borrowing a new or a "known good" transducer and seeing if it works then. If so, replace the transducer.
Let us know if these work or now.
Oct 15, 2009 | Eagle Fishmark 320 Portable Fishfinder
I have an Eagle Fisheasy fish finder & need to replace transducer do not know witch one to get. All i know is,it is a wide angle skimmer with a two prong connection
Sep 07, 2009 | Boating
I am looking for a owner's/operator's manual for an Eagle Silent Sixty 1 Depth Finder by Lowrance. This is one my Dad had for many,many years. It still works just fine although it would be considered an...
On the web transducer model XD-2 Find eagle model silent six/sixty will give you the owners manual for the unit mounted on the boat same as portable.
Feb 28, 2009 | Eagle Boating
A65 Transducer
jmiller,
Sound like your getting turbulence from the hull or your angle is allowing cavitation under the transducer. Look under the hull where the traducer is mounted and look for a part that has no obstruction including saltwater pickups, hull relieves, etc. The other thing to check is to take a strait edge on the bottom of the transducer to ensure the angle is slightly forward than the hull.
Bob
Sep 11, 2008 | Raymarine A65 Combo GPS...
Eagle Fisheasy 250ds Fishfinder Logo
75 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
