Question about Brother MFC-230c Printer
I can't fax to one particular number and they can't fax to me but we both can fax everywhere els and receive from everywhere els . What is the problem the two fax machines don't want to talk to each other?
  • brian408 Jul 08, 2010
    I don't think there is a broblem with the phone line because if there was I wouldn't get other faxes from other people from all over the place .
    Genius:
  • 1,040 Answers
Since you can send the faxes to others then it is possibility of that one of you has blocked the other ones number....
setting the both (i.e. yours and other ones) devices to factory defaults may help you...
Thanks...
Posted on Jul 08, 2010
  • 2,427 Answers
That isnt a problem with the machines.. It isnt possible ,, if it was then the machines wont fax at all..... Contact your telephone line provider...
We are having issues faxing to one particular number. We think our fax goes through, but spits out a Error 345*. Nothing is sent
fax machines talk to each other before sending data to ensure that the sender/receiver are on the same format and are compatible
for one particular number to be a problem indicates a fax number problem in setting the dialed number area code , dashes etc are all specific
ring the receiving department and ask to confirm that they are having trouble receiving faxes from your number as well
Dec 14, 2016 | HP Office Equipment & Supplies
HOW TO FAX
  1. Make sure the fax machine is plugged into a power source and also plugged into a working phone jack.
  2. Turn the fax machine on.
  3. Obtain the fax number of the destination fax machine.
  4. Gather the documents you want to send and put them in the order you want them to be received.
  5. Fill out a separate piece of paper called a coversheet with the recipient's name, fax number/phone number, your name, your phone number, a short message and number of pages (including coversheet).
  6. Lay the documents face-up in the fax machine feeder tray with the coversheet on top
  7. Dial the recipient's fax number - put 9 before the number and area code
  8. Press the "fax" or "send" button, depending on the particular fax machine model
Nov 17, 2014 | Office Equipment & Supplies
Cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers
"cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers"
If your machine can receive a fax transmission from one number, it will receive from all numbers.
If your machine can send to all but not to one particular number, please check that there is a fax machine there to receive it.
You can try to send manually and listen for beeps from the other fax -if one is present- then push the START button to initiate transmission.
If their machine is in working order, the transmission should start. (After the initial 'handshake' of course.)
Jun 16, 2011 | Office Equipment & Supplies
I can't send fax to Japan, but can make calls.
Dial the fax number in Japan with a regular phone. You hear how responsible you a fax from the other side? If you answer a fax can be heard, the more likely the issue is still in the phone company that gives you the link.
Jul 27, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
What does poor line condition mean? i can receive and send faxes but to one particular fax number is it my fax or the other side?
If this happening only on one fax number, its the other side, could be their line or fax machine.
Just make sure for youre end that the telephone wire is in the LINE jack of fax machine (NOT EXT) and other end should should go directly to wall jack (meaning no extention or splitter)
Jun 29, 2010 | Brother IntelliFax-2820 Laser Fax
Faxing
Maybe they gave you the wrong number. Call the number from a regular phone and listen for fax tones.
Feb 16, 2010 | Samsung SF-560 Plain Paper Laser Fax
No fax
le estas poniendo el cable de telefono en el roto equivocado, tienes que usar la linea regular de telefono, de lo contrario tendrias que tener un network ya setiado para ello con una pagina tuya, aparte poner el disco de network y configurar la pc para que lo registre y configurar el printer tambien, asegurate que el numero de fax funcione.
Apr 30, 2009 | Samsung CLX 3160fn All-In-One Printer
Strange problem
the problem is with their system, not yours. they are probably missing lots of faxes. They may for instance have a few phone lines which receive faxes called a "hunt". If one or more of their lines are bad they may not even realize it.
I suggest you call them and tell them what is going on.
Feb 10, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother Intellifax 2820
It could be a compatibility issues between the two faxes. If the other fax is particularly old its communication speed could be too slow for your fax.
Also don't rule out the line on there end. Many times in my job I've had Telephone company's check the line remotely and say its ok but its not until they come out to site that they find an actual fault.
Do a manual reception. Put your fax reception mode from automatic to manual. When the fax rings in pick up the line with the hook or speaker phone button and then press the start button. This rules out a fair part of the line correction. If you can receive of course.
Feb 06, 2008 | Office Equipment & Supplies
Sending faxes
SEEMS THE RECEIVING FAX IS SET ON AN EXTENSION , SO U WILL HAVE TO FOLLOW THE PROCESS. HAPPY FAXING OMNIPRESENT
Sep 05, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
Brother MFC-230c Printer Logo
78 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
