Question about Asrock 939SLI32-eSATA2 (939SLIESATA2) Motherboard
Asrock 939sli32-esata2 one long and 9 short beeps
  • raypayton Jul 08, 2010
    Same conditions: one long beep and 9 short beeps. I don't have any video. What does this beep patern mean?
  • 4,281 Answers
First pull csos cell from motherboard for 10 minutes so all settings defaults.
Then make sure RAM memory is working fine.
Try with another ram.
Make sure motherboard is not gorund with cabinet cover.
Pull motherboard from cabinet andf check it in outside of cabinet.
Then if you get display then put motherboard and make sure it is not gorund with cabinet.
Pull processor and it's fan then reconnect it remove dust from all parts.
Rmove pci card if anyt reconnect vga card if it not on board vga .
Reconnect both connection to harddrive .
Then check .
If sitll same issue then you need to repair motherboard.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jul 08, 2010
  • When you pwer up the computer press F1 or f2 or del or ALT +F2 key if you able to see bios screen then your motherboard is working fine .
    Then you need to check that harddrive is recgnized in bios or not.
    But if you are not able to see any display then change the RAM memory and reconnect the processor then if still same issue then your motherboard need repairing .
  • 4,737 Answers
You beep codes indicate that your memory (Ram) and Bios Chip are having problem.
First of all, disconnect the power cables, ide/sata, fans, etc.. (disconnect everything which are connected to the motherboard -internal/external) and remove the bios battery, wait for few minutes (5 mins) and again reinstall it. Now reconnect everything, power on and check the status. Same condition?
Then, re-seat the Ram, and if there's no positive effect replace it and try booting it again. In case there's no changes, you need to check the Bios Rom Chip. If you don't know how to remove it, please don't do it, you may damage the chip or the board. You need to call a technician to replace it or to re-seat it.
If replacing the Bios Rom Chip isn't helpful, then your only option is to replace the motherboard.
I could only wish you good luck.
No video on asrock p4i45G motherboards
Hello the homepage is here:
http://www.asrock.com/mb/Intel/P4i65G/?cat=Manual
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
http://www.computerhope.com/issues/ch000996.htm
Beep codes:
http://www.computerhope.com/beep.htm
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Nov 26, 2012 | Asrock P4i65G Motherboard
Hi, just swaped out a harddrive now my Mainboard *4 core Duel Sata2* does a single beep, pause then rapid beeps. can you help
Please count the number of rapid beeps. 3 short beeps is a memory error. 8 short beeps is a display memory error. 9 short beeps is a ROM Bios checksum error and 10 beeps is a CMOS shut down read/write error.
The solution will depend on the error. For a memory error, remove all of the memory sticks then reinsert each one separately and reboot the computer. If the board continues to beep 3 times, that stick is bad or the memory slot has failed.
The complete beep code list is provided here: http://www.asrock.com/support/qa/TSDQA-01.pdf .
I hope this helps.
Mar 27, 2011 | Asrock P4I45GV R5 Motherboard
I wish to know if DDR2 RAM can be used on the motherboard. The vendor has supplied me with one DDR1 RAM 512MB DDR400 CL2.5. I am having 2 pieces DDR1 RAM from my old machine 128MB EACH. I wish to know if...
No you cannot use it .... *********** board will not support DDR2.... but if have the slot for both DDR1 then you can use DDR1.. but i will suggest you to use Ram for same memory .. But you can use 521 & 128 together , no problem.
thanks for rating Good luck
Jan 14, 2011 | Asrock 939SLI32-eSATA2 Motherboard
What does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Jun 01, 2010 | Asrock 939SLI32-eSATA2 (939SLIESATA2)...
Asrock p4vm8 beep codes
How does it sound? Does it beep with memory card seated? one long- 3 shorts beep bad graphic card, one long repeated 3 times bad memory card
Apr 12, 2010 | Asrock P4VM8 Motherboard
I just installed a used Asrock K7S41GX board which is working just fine exept I have no sound through my external speakers. The internal speaker on the the board beeps on startup but nothing after that. Do...
If you hear just one short beep on the onboard speaker it means that everything is fine. You should download the drivers for the onboard sound from Asrock website.
May 18, 2009 | Asrock K7S41GX Motherboard
Audi device not working on ASrock 939SLI32-eSATA2 motherboard
According to the specs of your board you should need a AC97 HD driver.
Post your results, especially if this doesn't resolve your issue...
Mar 17, 2009 | Asrock 939SLI32-eSATA2 Motherboard
No boot and beeps
The exact fault code indicates RAM or a problem accessing the RAM.
Check that you are using recommended/Approved RAM as ASUS and ASROCK (the budget arm of ASUS) are notoriously fussy with RAM.
If it all checks out then your northbridge could be dead and it will probably be scrap.
Feb 21, 2009 | Asrock K7S8XE Motherboard
Asrock 775 twins hdtv
Try, remove the memory and clean the contact point using eraser.
Oct 19, 2008 | Computers & Internet
Asrock 939SLI32-eSATA2 (939SLIESATA2) Motherboard Logo
233 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
