Question about LG 32LX1D 32 in. LCD Television
LG 32 LX1D won't turn on.
We came home from being gone over the weekend to our LG 32LX1D not turning on. Where there is usually a green light to indicate the power is on, there is now a blinking red light. Can't find anything in troubleshooting in the owner's manual.
  • 11,361 Answers
Unplug it from the wall for about an hour and see if it resets itself. Otherwise you will need to do troubleshooting insdie the set.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 08, 2010
My lg lcd turns on.then turns of
Unexpectedly Turning Off
Many LG LCD television owners have reported a problem
where their television will power itself off or will only work
for short periods of time.
The problem usually occurs in brand new televisions and requires
the television to be sent to LG or your local electronics repair
shop to be repaired.
Jan 04, 2010 | LG 32LX1D 32 in. LCD Television
Won't turn on. blinks green 5 times and then back to red.
Check your owners manual for parental locks, and timer controls first to see if the tv has been locked. Some tv's require an unlock code (entered from the remote control) to reinitialize normal start-up. Usually when the LED blinks in sequential intervals it indicates a circuit problem. A bad power supply circuit may be the cause, control regulator too, or the interface circuit is defective.
Jan 04, 2009 | LG 32LX1D 32 in. LCD Television
Lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Sep 27, 2008 | LG 32LX1D 32 in. LCD Television
LG 32lcd2d
Sounds like your cable is off or your not on chan 3 . Can you go to setup and find cable , air ect ? And see if that does anything ? Check all your coaz and hdmi and make sure they are tight as well
Jun 25, 2017 | LG 32LX1D 32 in. LCD Television
Lg 42inch lc7d high pitched noise while off
Sounds like the power supply is making that noise. At this point I would just exchnage the TV.
Mar 03, 2008 | LG 32LX1D 32 in. LCD Television
LG 32LX1D 32 not turning on
Hi, I think you have to get it checked out by a profesional, unpluging your appliances is a good idea but damage can also ocuur the moment you plug them back on. If you want to try it could be that a fuse is open there not normal fuses inside (small chip fuses surface mount)
Aug 24, 2007 | LG 32LX1D 32 in. LCD Television
MY lg 32lx1d is not turning on..
I had the same sympton on my tv...it worked fine one day and the next day it would flash a green light a few times you would see the screen power on, but still be dark then the power light would go red. I couldn't do anything on the tv no menus or sound. It turned out to be a bad power supply, a new power supply will run around $200-300 - in my opinion it wasn't worth fixing. My neighbor was able to fix my tv - he repairs electronics - ended up cost me $100.00 - its been running for 7 months now no problems so far...I can have him fix this for you if you are in the area - shipping makes this to expensive..he is located in south jersey...or you can try a tv repair shop ( i called for this but they wanted between $75-100 to just look at the unit + repair cost - i would of been back to the 200-300 range) let me know if you need help...John
netplus@comcast.net
Power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
Aug 23, 2007 | LG 32LX1D 32 in. LCD Television
LG 32LX1D 32 in. LCD Television Logo
2,005 people viewed this question
Computer Repairing
Computer Repairing
