Question about Viking 30" Professional Select Built-in Electric Single Oven - VESO130
Viking oven door problem it won't seal tightly where the bottom oven is nice and tight. how do I fix this problem...how do I tighten the top door of the oven?
barkencoa
  • 3463 Answers
SOURCE: Viking Double Electric Oven VEDO127T
Probably a faulty heater element, some ovens have more than one element in the compartment, so it is possible you only have part heat.
Posted on Dec 02, 2008
barkencoa
  • 3463 Answers
SOURCE: Re Neff B1451 oven door not sealing against oven body at top
The door hinges are not adjustable, the only solution is to replace both door hinges as it is the springs that are weak.
Go to; http;//www.youtube.com/watch?v=
Plz rate my solution.
Thanks.
Posted on Dec 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Thanks.
Posted on Jan 06, 2009
  • 38 Answers
SOURCE: oven door won't close tight - light stays on
Replace door hinges.
Posted on Mar 08, 2009
SOURCE: Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Posted on Apr 01, 2010
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Oven door kleenmaid wont shut tight enough
Some are made where you just pull up on it and some you actually have to remove the bolts and stuff
Jul 29, 2012 | Ovens
It is always slightly open at the top.
I sounds as if you are talking about your oven door. If so it shouldn't be, it should be sealed tight. If the seal at the top of the door is open you will lose a lot of heat from the oven. The solution is to get the oven door springs replaced.
Feb 14, 2011 | Ovens
Decor double oven - Door adjustment
Unfortunately yhe door hinges are non adjustable.
The only solution is to replace the hinges as a pair.
Hope this helps.
Dec 15, 2009 | DCS WOS-230 Oven
Thanks.
Jan 05, 2009 | Dacor ECS130 Epicure Electric Single Oven
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Viking 30" Professional Select Built-in Electric Single Oven - VESO130 Logo
178 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
