Question about Saeco Royal Professional Espresso Machine
New machine out of the box says "warming up" and that's all
Brand new royal professional was just delivered, we filled with water, put in coffee beans, but all it says is "warming up" - won't make coffee
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Please check the connections on the board ( when you look from right hand side through the grill ) are all connected. It is possible one of the sensor wire is disconnected while in transport.
Posted on Jul 13, 2010
My Saeco Royal Professional says coffee beans empty although it is full
hi,
there is a small measuring device between the grinder and the brewer, that measures grind coffee flowing into the brewer. the brewer is the removable part on the right side of the machine.
it looks like that the measuring device is clocked or in worse case broken!.
my suggestion:
1.open the door on the right side
2. remove carefully the brewer/brew unit
3. clean it under warm running water
4. clean out the surrounding area, coffee pan etc.
5. check the measuring device for clocked coffee. it is square, has a small flap and easy to access with the door open. take a soft brush and clean the area, there might be a lot of ground coffee!
6. carefully re-insert the brewer acc. to manual, do not force in place.
7. close the door and use the unit.
you might also remove all beans and clean the burrs, the ground coffee outlet and check that it is free and not clocked as well. otherwise no ground-coffee will reach the measuring device!
good luck!
Sep 30, 2014 | Saeco Royal Professional Espresso Machine
Saeco Royal=,beans do not appear to be grinding, machine whirs for 30 seconds then says add beans have tried 2 different types beans after cleaning bean hopper works first 2 coffees ok then stops
Coffee Beans were roasted by local business,believe they were either not roasted enough or over roasted causing the problem, I have since tried Supermarket(Vittoria Roasted Beans) and machine is working perfectly.
Thankyou
Keviroy
Oct 02, 2009 | Saeco Royal Professional Espresso Machine
Small coffee and coffee not dispensing?
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
Aug 31, 2008 | Saeco Royal Professional Espresso Machine
Saeco easy...
Your grinder needs cleaning- are you using oily beans and/or storing beans in refrig/freezer? Both are a problem for grinder. Also, grinder should not be set to "fine"- it will definitely cause clogging and the situation you point out.. After celaning grinder, will need to re-set it.
Jan 26, 2008 | Saeco Royal Professional Espresso Machine
Machine not working!!
the circuit board is probably fry when you put back the grinder the ajustment are sometime tricky maybe it grind the coffee to fine that why it doesnt drip good try that and if everything work fine except the water level so be it there probably something fryed in the board good luck cheers
Jan 22, 2008 | Saeco Royal Professional Espresso Machine
Water tank empty
the sensor is not working.. try to identify the sensor inside the tank and change it..
Dec 29, 2007 | Saeco Royal Professional Espresso Machine
Royal coffee bar
You have the go into the menu and change the setting on the "direct water supply" option to off. Your machine comes from the factory set to use direct water feed. This option tells the machine water supply to use.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
Dec 16, 2007 | Saeco Royal Professional Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
245 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
