Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Colors don't line up. Replace convergence IC ?
From what I've read so far, I should replace both the convergence IC's (part stk392-560).
I downloaded the service manual, but haven't been able to locate them on any of the board diagrams. Is there a different number Sony uses in their manuals?
Which board is it on?
  • Nathan Apr 21, 2008
    After a bit of searching, I found the IC's on the D board.
    They are called IC8001 and 8002. Same Sony part no. 8-749-019-08 for both.
  • Sony Master
  • 8,617 Answers
They are STK392-560 you can get replacements here.
http://servicemanuals.vstore.ca/
Posted on Apr 25, 2008
How do you fix the color to a model 43fdx11b hitachi
Hello!you mean: colors out of convergence? nothing you can do about that, unless you replace 2 convergence amplifiers I.C. chips, plus all those burned 1 watt low ohms resistors with exact values, which only could be obtained via service manual or schematics. After resistor is burned, there is no way to read color code properly, due to partial evaporation of pigments. this is a "pro" job. If you try or tried, already to converge those "stubborn" crosses, there is more to do, even after you removed and replaced two 20 pin I.C. chips, soldered dead into sweep module, plus located and replaced resistors with precise values, you need to get your settings back to normal, by going into "factory service mode' or, at least into "convergence alignment" menu and fight with those crosses!Don't forget the white "****"! Otherwise, you will be re-servicing your set all over after 30 days of usage.good luck,Alex.
Feb 01, 2012 | Hitachi Televison & Video
Accessing Service menu to fix convergence
How far off are the colors misaligned such that you need to enter the service mode to fox them? If one or more of your colors has taken a dramatic shift in position, especially on any edge, then do not attempt to correct through the menu. If one of your convergence IC's has failed then the colors will not align on the screen. If you try to correct this in the menu, you will only be screwing up all the settings and making the set worse. When the IC is replaced with a new one your colors will still be way off, not because the new IC is not working, but because now the menu settings are too far off. I have been to many houses and spent 45 minutes replacing a burned out convergence IC followed by more than an hour realigning everything the customer messed up.
Aug 18, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
CONVERGANCE PROBLEM TOP/BOTTOM LEFT OF SCREEN UNABLE TO CONVERGE NUMBERS 1 4 7
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. Your symptom sounds like a damaged convergence IC.
If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
*** VERY IMPORTANT NOTE***
If your set is not producing a clear picture and the colors are not lining up, do not continue to watch the set as this can lead to further failure and possibly damage the individual CRT’s in the set.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
How do I tell if the IC’s are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC’s. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Mar 15, 2010 | Televison & Video
I own a kp-51ws520 51 in rear projection hdtv-ready and the flash focus does not work. are there convergance chips in this set. If so what is the part number
If your colors are not lining up on the picture try to use the customer convergence menu to line up all of the colors.
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem.
With any Projection Television that has a damaged convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Their site is
You can also try
http://www.tvrepairkits.com/ .
Here is what they offer.
•OEM Sanyo Convergence Chips. These are genuine OEM Sanyo chips - Not generic ones. Sanyo was the primary supplier of convergence chips used in TV sets made by Philips, Sony, Hitachi, Panasonic, Toshiba, Mitsubishi, and many others)(2 per kit )
•Convergence Resistors
•Pico Fuses
•Thermal Paste
•Photo Instruction Manual - Complete Instructions on how to repair your TV. This is a step by step photo instruction quide that will walk you through the repair. (Download Version - PDF format allows you to view/print from your computer)
•Desoldering/Soldering Tips (Instuctions on how to solder )
•Email/Phone/Live Chat Support
asnowman
Dec 07, 2009 | Sony KP-51WS520 51" Rear Projection...
Hello
Their site is
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
asnowman
Dec 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
The Blue Color on the covergence is bowed to the right
Ur IC in ur Convergence board is short or dead.
Must be replace.Adjusting the yoke colors plastics wheels alone wouldn't help or work.
Aug 19, 2009 | Televison & Video
Mitsubishi 61 in Rear Projection
No they are very easy with basic solder skills. you can get replacements aat this link, and they send free installation instructions and provide free tech support to help you do the repair. you need to replace both of them. Heres the link
Apr 17, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
157 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
