Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
How do you replace the blade belt on a john deere rx75 lawn mower
  • 42 Answers
SOURCE: Lost the bolt/nut to my riding lawn mower!
That is a cap screw you are talking about. The size of it is 7/16" X 1-3/4". The John Deere part # is 19H2563, but I am sure you can just get one at the local hardware store. I could not find out for sure, but on most blades they use a fine-thread bolt/screw. If you can tell the difference, check before you buy, or just buy both and see which one threads in easily. Hope all this helps.
Posted on Apr 01, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
agent91
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
farmerbear
  • 490 Answers
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
Posted on Aug 21, 2010
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
My rx75 runs well but will not engage the deck is it electronic?
The mower deck is 100% manually controlled with the yellow control handle. The linkage may be out of adjustment a lot, especially if new belts are now broken in. When engaged, the blade drive belt should be quite taunt,but not like a banjo string. Adjustment is easy and can be found on the operators manual.
Jun 18, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 belt routing diagram
I found manual on amazon... so you can take a look there Amazon com john deere rx75 manual. I hope this was helpful. cheers
Jun 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
Mar 31, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
1,882 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
